HT lead order! Please help
Discussion in 'Electrical' started by fly, Jun 10, 2007.
  1. FLY
    fly Forum Member
    Hi guys, i'm sure this is a fairly regular thing for the plonkers who don't label their HT leads in someway before changing the distributor cap etc... well i didn't!
    And now it won't start so i was wondering if anyone had any pics of a mk2 driver (1.6) that they could show me so i can get them in the right order.
    Then at least if they're right i can check my other possibilities out!?
    Thanks,
    Aaron
  2. Obvious Forum Member
    Manchester
    As far as I know, the easy way of doing the order is usually shortest lead goes to the coil, and the longest to the 1st spark plug/cylinder, just do the rest via the size.. so second longest to 2 and so on and so on...
  3. StuMc
    50? 20` 47 N - 06? 57` 57 E
    Not necessarily...
  4. ambrose89
    ambrose89 Forum Member
    on back,crap in eyes, beneath car
    1-3-4-2 iirc
  5. rubjonny
    a picture as they say, speaks a thousand words:
  6. FLY
    fly Forum Member
    That pic was exactly what i was after and they were wrong, but are no longer!
    However, still not starting and the battery light is coming on but there is loadsa life in the battery and all other anciallary items work i.e lights, wipers etc.
    What should I check?
    Thanks,
    Aaron
  7. rubjonny
    pop off the dizzy cap and look at the notch on the dizzy, set sparky wire #1 to the terminal that matches :)
  8. StuMc
    That`s the firing order. It won`t tell which lead goes where! ;)
  9. stumpy1976
    stumpy1976 Forum Member
    West London
    Is this the same setup for a PB engine???
    As im having difficulties in getting her starting and running correct.... Plus when the Camshaft & No'1 piston are at tdc....where should the dizzy be pointing???
  10. rubjonny
    that is a PB engine :)
    doesnt matter where the rotor arm is facing as long as it lines up with the notch on the dizzy housing. However if its waaay out the hall sender can fowl on the block, if that happend loosen the lower cambelt cover and jiggle the belt to move the intermediate shaft round a bit. The pulley for it is at the front of the block just below where the belt dissapears into the lower cover if you get me?
  11. stumpy1976
    West London
    wow.....not quite sure how ...but my car has been running (albeit badly) on the ht leads in the wrong place!!!!
    woops
    Cheers RJ
  12. perryqhill Forum Member
    Durham
    Will this be the same for a mk3 2.0 8v GTi?
  13. rubjonny
  14. Phil. Forum Junkie
    Northern Ireland
    Set piston 1 to TDC, rotor should then be pointing at plug lead no1. Use 1-3-4-2 firing order to locate correct lead positions on the dizzy. C/w for 8v's, A/C for 16v. ;)
