Individual Throttle Body PORN thread.
Discussion in 'Throttle bodies & non-OEM ECUs' started by Admin, Dec 1, 2009.
Tags:
  1. HPR
    HPR Administrator Admin
    Do curved trumpets work? Bloody expensive.
  3. Brookster
    M1 J40
    good question, would like to see any results ;)
  4. HPR
    s14-rennsport-teile_07.jpg Aslong it has a nice radius there wont be much inbetween straight or radius .... in some cases it can even be a plus, same apply to manifolds, btw lots of high end engines have radiused trumpets
  5. notenoughtime
    Essex
    But is that so they fit under the bonnet Hugo? The bmw above is obviously on the slant as are many engines nowadays
  6. HPR
    Yes, install limitations to fit under the bonnet.... but at the same time the injector spray central into the runner for good atomisation
  7. Dave
    Sligo, Eire
    In fluid dynamics (hydrodynamics), of which aerodynamics is sub category, any disruption from 'straight' laminar flow will cause turbulence!
    (Fluid dynamics was part of my Mech Eng degree course)
    Turbulence in a combustion chamber is not necessarily a bad thing of course.
    One could look at this by making two models, one straight and one curved, in clear plastic.
    Suck smoke through with a vacuum cleaner and see what happens!
  8. notenoughtime
    Essex
    We await your modelling skills [:D]
  9. HPR
    Indeed, turbulence in a combustion chamber is not necessarily a bad thing, air and fuel need to mix well before it enters the combustion chamber ( port injected) while combustion is a very complex proces....much theory, but in the end it need tried in the real world praxis on a dyno....
    Dave likes this.
  10. Dave
    Sligo, Eire
    Don't hold your breath!
    But next year Lainey says I can build a 'big' three car garage.
    First job is to sort the stripped out 90 20V Q.
    If you did not know it, this car was the first AUDI with high pressure sequential injection.
    Hitachi made it because Bosch were scared!
    So my thinking is:
    To get the maximum out of this N/A super motor it will need two injectors and two ECUs.
    Models may well be needed!?
  11. notenoughtime
    Essex
    You can do sequential injection on one ecu but Im guessing your using the original ecu so two ecus and Two sets of injectors
    Dave likes this.
  12. jamesa Forum Junkie
    Abz
    This should be running soon ...
    Toyotec and Dave like this.
  13. Dave
    Sligo, Eire
    That's what I meant. Ta so!
  14. Toyotec
    Toyota 4AGE 20v throttles.
    I curved the intake runners on the ones I made up and deleted the Toyota fuel rail, using a 1.8T part to inject behind the valve.
    This application in HPRs post brings the ITB closer to the valve with some sort of flange adpator and uses the OE Denso injectors and maintains length without hitting the bonnet with a curved trumpet.
    Different approaches I suppose.
  15. knarfmk1 Forum Member
    Holland
    DSC_0084_original.jpg DSC_0099_original.jpg DSC_0094_original.jpg DSC_0096_original.jpg DSC_0095_original.jpg DSC_0089_original.jpg DSC_0092_original.jpg DSC_0103_original.jpg Kawasaki 46mm ZX12R ITB's on my 1.6 16V ARC/AFH hybrid, max rpm 8500 (limited by standard cranck), aiming for ~190bhp:
  16. notenoughtime
    Essex
    One of my favourite threads this
  17. Paul 16v Forum Member
    [​IMG][​IMG][​IMG][​IMG]
    Sent from my iPhone using Tapatalk
    HPR and notenoughtime like this.
  18. HPR
    12141602_838322276285517_8770785684702196933_n.jpg 12107249_838322779618800_6301459832847074059_n.jpg 12119138_838322806285464_6148069352434558719_n.jpg
    gasco, Toyotec and Savagesam like this.
  19. Savagesam
    They're gorgeous! :o
  20. gasco
    gasco Paid Member Paid Member
