Installing 1.8t AGU into T4
Discussion in 'Electrical' started by Watten, Jun 7, 2022.
  1. rubjonny
    One thing you may need to earth the bonnet switch pin if you don't have one as iirc the oil warning won't go out till it sees a bonnet open trigger
  2. Watten New Member
    Yeh, put in a new mk4 switch, however I think the wire needs extending, or the connector needs replacing as its not on 100% (I think).
    Is there a link on here to the fuel pump mod?
  3. rubjonny
    this is how you mod a mk4 sender to suit mk1/2/3, you see the blue wire is cut then re-soldered to the other end of the board. may want to ask around to confirm if the T4 needs it, or if its even possible as I cant say either way on that one sorry :(
