K-Jetronic DIY Pressure Tester
Discussion in 'K-Jetronic OEM injection' started by trackdaygtimk2, Apr 21, 2016.
  1. Hi all
    I know this subject has been covered many times and the excellent sticky by gti_kev explains how to do a pressure test and WUR mod, but has anyone managed to find out what items are required to build your own pressure tester.
    I saw a thread recently where someone built there own but he could not remember the parts that were supplied to him by pirtek
    The only pressure testers i can find for the k-jetronic are 75+ and considering i am only going to use it once i would rather build my own (tight i know)[:D]
    I know a ball valve stop tap and various other fittings are required but what sizes and quantities etc ?
    Help would be appreciated
    thanks
  2. Sirguydo
    Nige the diy guru built one and shows how it's done early on in his epic build thread :thumbup:
    I bought a cheap test kit off eBay and a additional ball tap from tool station
  3. Sizes
    What size threads are required for the ball tapp ? do you need a female/female one, male/female ???
  4. Tristan
  5. Great bit of info thanks Tristan, i will give Derek a try
  6. Gaz37 The Grouch. Paid Member
    I cobbled one together with a pressure gauge, an old WUR feed hose, some PTFE tape and jubilee clips, probably not H&S approved but it worked
  7. dent doc New Member
    Ya should have a pm
  8. Here is the list of what is needed all, good luck finding the bits in the UK,i think it is going to work out more cost effective to buy a kit off the shelf !
    1 4089K61 1 Each Multipurpose Gauge Plastic Case, 2" Dial, 1/4 Npt Bottom, 0-100 Psi
    2 4464K48 1 Each Type 304 Stainless Stl Threaded Pipe Fitting 1/4 Pipe Size, Tee, 150 Psi
    3 5779K109 2 Each Nylon And Nickel-plated Brass Tube Fitting Adapter For 1/4" Tube Od X 1/4" Npt Male Pipe
    4 5269K311 1 Each Steel Compression Tube Fitting Straight Adapter For 6mm Tube Od X 1/8 Npt Male
    5 5779K129 1 Each Nylon And Nickel-plated Brass Tube Fitting Adapter For 1/4" Tube Od X 1/8" Npt Female Pipe
    6 8359K14 1 Each High-strength Clear Nylon Tubing .190" Id, 1/4" Od, .030" Wall Thickness, 25 Ft. Length
    7 4912K72 1 Each Miniature Chrome-plated Brass Ball Valve Wedge Handle, 1/4" Npt Female X Male Connections
    Part numbers ref McMaster-Carr USA.
