Kenwood Mask Connections
Discussion in 'ICE' started by GTi_8v, Oct 28, 2003.
  1. GTi_8v Forum Member
    I'm getting a Kenwood Mask head unit, and have the original 1989 Golf mk2 wiring.
    Does anyone know if there is an ignition positive going to the iso connectors that the new headunit will use, so that when the ignition is turned off, the Mask faceplate will hideaway?
    I'm willing to put one in, but was wondering if it will already be there?
    Thanks.
  2. TIM
    Tim Forum Addict
    i dont think there is,
    but you can use the power feed to the electrice fans as one, (you can only use the fans when the ignition is on)
    HTH
    tim
  3. GTi_8v Forum Member
    Sounds good, Thanks!
    Should be turning up Monday, just missed the deadline for a saturday dlivery! [:x]
