Loss of power momenterally
Discussion in 'K-Jetronic OEM injection' started by datsunjay, Aug 14, 2018.
  1. datsunjay Forum Member
    Ill check for spark at the coil later and also check the ignition amp, is the ignition amp located at the ecu?
    Cheers
  2. GVK
    Yes it's the little square thing on the ECU bracket
    Stuart webb likes this.
  3. datsunjay Forum Member
    Perfect, I'll get it checked and report back.
    Thanks
    have you checked the pins in the ecu & spark module plugs yet, plus general wiring condition? on mine it cut out on me and all it was a bit of dirt on the ecu p[lug. car would crank over, run the fuel pump as expected etc just wasnt triggering spark module to fire
  5. datsunjay Forum Member
    I pulled the Ecu plug yesterday and all the pins looked perfectly clean.
    When you say spark module is that the TCI? The small black box where the ecu is?
    I also unplugged that and everything seems fine.
    I'm hoping to pick up a new module today and try it this evening at some stage.
    yarp spark module = tci :)
    do you see the rev counter jiggling while you're cranking it on starter?
  7. datsunjay Forum Member
    To be honest I never took any notice of the rev counter while cranking, but I'll check that later.
  8. datsunjay Forum Member
    Just checked this and yes the rev counter does jiggle when cranking over.
    Won't have the tci until tomorrow
    Edit...Looking at the rev counter counter now it rises slightly when ignition is turned on but now isn't jiggling when cranking
  9. rubjonny
    ok have a look at the red/black wires on the coil, make sure they're clean and tight. there is a spade plug inline with one of these wires for the isv controller too, try unplugging that just in case module or wiring to it has gone bad somewhere. on the other side of the coil is the trigger wire from the spark module check that too
  10. datsunjay Forum Member
    Ok thanks, I'll have that checked later, also have a tci module coming today which I'll try.
  11. datsunjay Forum Member
    Well the tci has sorted the problem, stated up first turn of the key.
    Thanks for all the help guys
  12. GVK
    Good news, thanks for posting the remedy.
  13. rubjonny
    nice cheap fix then :thumbup:
