Lumenition Distributor conversion.
Discussion in 'Carburettor' started by KeithMac, Jun 5, 2022.
  1. KeithMac Forum Junkie
    Kazakhstan
    Hello all, firstly I've put this in the carbs section as it goes hand in hand with the Bike Carb conversion.
    Has anyone run the Lumenition Optical dizzy on a Mk2 Golf on here and how did it behave.
    I see @Jon Olds runs the fancier version of this?.
    I'm trying to go old school and simple with my restoration so the Lumenition looked a good bet (fit and forget?).
    Is it a Bosch distributior kit I need for my Mk2 16v?.
    Cheers all.
  2. Jon Olds Forum Junkie
    Run one (or two 25+ years) fit and forget.
    You can get a mechanical advance curve to give you your 32 degrees (or whatever) with a four wire system
    to an amp.
    I have collected a box of similar stuff over the years, as it was obvious to me that this would eventually be hard to come by
    Pair 45's, big cams, more compression , ported head, tubular manifold, easy 200 or so bhp
    Jon
    KeithMac likes this.
