Max boost on a stock K04 turbo
Discussion in 'FSI (inc. GTI 2.0T)' started by Southy_GTI, Mar 21, 2013.
  1. Southy_GTI Forum Member
    Turkmenistan
    Hi Guys
    I've seen some data on the K04 compressor map and various comments on the net that the max pressure for a k04 on a sub 2.5L 4 cylinder engine is around 22psi?
    Is this accurate as I've seen a lot of Cupra R's and Audi S3's running 27psi peak, tapering down to 24-25 pounds at redline!
    Is this safe / wise?
    thanks!
  2. Spuugemmer New Member
    The K04 will do 1.85 bar (~27psi) only not for a very long time.
    It is better to get the results from ignition and normal (20-21 psi) boost pressure.
    You can expect 375-385 HP if there is enough fuel (hpfp).
  3. Notso Swift Forum Member
    You should look for the compressor map
  4. Toyotec
    ^^ You can.
    However I do agree with what Chris said from mapping experience.
