Mk1 20vt ME7.5
Discussion in 'Electrical' started by porttimies, Feb 19, 2018.
  1. porttimies New Member
    Hi people,
    I'm doing AEB swap with ME7.5 on my Mk1 Golf, it has early Ceramic fusebox.
    The engine loom is ''standalone'' it only delivers wires for dash gauges.
    i have done everything exactly like in the rubjonnys harness quide(i hope im right) but im now having an issue when im trying to power up the ecu/engine loom.
    I have red/green connected back of the fusebox straight to the permanent live,
    Fuelpump/sensors,n75,lambda relay goes like so:
    30 - permanent live
    85 - BAM ecu purple/white wire
    86 - ignition live
    87 - to pump and engine stuff(blue/yellow wire)
    The problem one is: I turn the key, relay pulls for 2 seconds and lets off, measured purple white,it ground's only for that 2 seconds, but why?
    As i take off the purplewhite from the relay holder and put wire that goes straight off to grounding spot, the relay works like charm and i get power to ecu as much so i could get it connected to VCDS.
    VCDS shows:
    Could the code P1609, do the purple/white wires problem as its trying to ''shutdown'' the engine?
    Problem 2: As i connect the ECU relay in the socket, it starts pulling straight away, i measured and its getting power like so.
    Thanks already people
    -Sami
  2. Toyotec
    I suspect so.
    Might need to be coded out.
