Mk1 golf ‘83 fusebox holder
Discussion in 'Electrical' started by GTI_LOUIS, Oct 9, 2023.
  1. GTI_LOUIS New Member
    Hi guys, bought my mk1 some years ago resto and engine swap 99% there. The problem I have is the car has been turned to a track car at some point and or LHD and some clever [xxx] has cut the brackets off the firewall/bulkhead that holds the fusebox.
    Has anybody got some of these brackets in a shell that is being cut that I can buy or am I going to have to make them, if it’s making them could somebody please take clear pictures, thanks :thumbup:
  2. Zender Z20
    You're in luck, (very dusty) shell's stripped bare at the moment...
  3. GTI_LOUIS New Member
    That is perfect mate, really appreciate it :thumbup:.
    I’ll post when I’ve fabricated something that might look similar:lol:
  4. PhilRyder
    A careful cut would bolt in, you wouldn’t even need to weld.
    Give MK2 Spares a call and ask them to cut one out for you (send the above pic to them to explain).
  5. GTI_LOUIS New Member
    Fabbing one up now @PhilRyder.
    I’ll be going down the rivet in route because the cars got the loom and carpet in now, didn’t want a rouge bit of weld sputter causing a wiring fault or fire :lol:.
    I’ll post pics after :thumbup:
  6. PhilRyder
    I did say bolt in, not weld...........
  7. GTI_LOUIS New Member
    @PhilRyder sorry mate didn’t see you blatantly wrote “you wouldn’t even need to weld” :lol: was skim reading.
    I have fabricated one now and fitted, not a factory look but close enough.
    measurements for fusebox:
    W: 200 mm
    D: 33 mm
    H: 95 mm
    Side lugs are 65 mm up and 15mm in to the centre.
    Pics to follow. (don’t all order at once):lol:
    IMG_4311.jpeg IMG_4313.jpeg IMG_4314.jpeg IMG_4318.jpeg IMG_4319.jpeg IMG_4320.jpeg IMG_4321.jpeg IMG_4332.jpeg IMG_4330.jpeg
    PhilRyder and Zender Z20 like this.
  8. PhilRyder
    Good skills :thumbup:
    GTI_LOUIS likes this.
  9. stephen stanyer Forum Member
    I think you did well making that just from pictures.
