Started re fitting the MS1 ECU now its back from Toyotec. Fitted a Audi Dizzy from a 6A Engine Need to check the Dizzy connections are they No1 top left , No2 Top Right No3 Bottom Left No 4 Bottom Right ?
t4 turbo hello did you have any problems with the t4 after installation of the turbo???? thanks Iam from belgium
Havn't fitted the Turbo yet but my mate has done the same conversion and its running excellent. 5th gear conversion complete 0.701 ratio Old Gear New Gears
3 leg pullers but 2 leg would be better have you tried anyone on T4 Forum , i have a 29tooth small gear nocking arround.
the original diesel pump is still attached, or is that also changed?? have you more pictures of the engine?
Original Bosch Diesel Pump its a straight forward conversion easily done once you have all the parts.
Some M&H 22" X 9 X 13 Racemaster slicks to go with the Weller Roadsport Wheels. 13.38 sec @ 106mph with the BF Goodrich tyres last time out Nitrous is also complete now.
Test fit of the Weller's on the MK1 , Theyclear calipers with the ET10 offset and no spacers required. Coilovers will need another 25mm lift to clear tyres under braking Finger crossed lower 12's NASP is the target with a bit of Gas maybe better.
