MK2 1.8T Conversion Thread
Discussion in 'Mk2' started by Richard Mk2, Jul 2, 2011.
  1. welshwizzard88
    welshwizzard88 Forum Member
    Devizes
    I have a corrado vr6 one left over think i need to get some slim fans.
    Intercollers anyone preferable rated 300bhp?
  2. welshwizzard88
    Devizes
    Just bought Omex 600 ecu so going SEM. Longlife amesbury wi build me a 2.5 turbo back system for 450. Just need to sort out a Intercooler!!
  3. Richard Mk2
    London / Bucks
    I've got a fair few bits and pieces gathered up for the conversion. Will update in my project thread once i'm back from the new forest. I'm still undecided on which intercooler to go for? Its got to be a fmic. I've been advised by a mate to go for a sprinter one. Its the pipework which will be a pain!
  4. shaz8389
    shaz8389 Forum Junkie
    Merc Sprinter one.
    Another vote for the "Sprintercooler"
  5. welshwizzard88
    Devizes
    What bhp can a sprinter one take/ work efficently at?
    I will be fitting a k04 and SEM so will hopefully see 250 BHP ?
  6. dsj20v Forum Member
    sunny hampshire
    sprinters are ok but if your going to running 250+ ko4 id look into getting a good quality fmic
  7. Richard Mk2
    London / Bucks
  8. welshwizzard88
    Devizes
  9. Richard Mk2
    London / Bucks
    I think i'll go for this then.
    It does look good quality tbh :thumbup:
  10. foxyjay Forum Member
    Guys, will this fit a K04 on a BAM fitted to a MK2?
  11. Richard Mk2
    London / Bucks
    Welsh wizard above is putting a 1.8t in his mk2 with a ko4
  12. welshwizzard88
    Devizes
    If you are using k04 023 from tt the this does not fit longlife are building me a turbo back exhaust for k04 for 450
  13. Richard Mk2
    London / Bucks
    Just wondering, where the hell does the turbo coolant return and feed pipe go / come from ?
  14. Richard Mk2
    London / Bucks
    Right then, just a quick update.
    Ive got the loom currently in the hands of R.J. Once its back i want to get the 20v in asap, but need to get a few things sorted before hand.
    As above on the previous post, where the hell does the turbo coolant feed and return go to on the engine ?
    Also im undecided on what rad and fan setup to use ?
    Would like to hear from some of you who have done the conversion recently and pictures would be great.
    Cheers :thumbup:
  15. Admin Guest
    what number are you quizzing in your post?
  16. Richard Mk2
    London / Bucks
    Just found this info below in a previous post in the thread.
    Looks like number 11 is the water feed. But would you know roughly where the return goes ? Does it go back into the header tank. :thumbup:
  17. Admin Guest
    i think it heads back into the rail that sits next to the inlet manifold, tucks underneath, there is also where the hearder tank feed goes to and from. I've removed all of that as i'm not using it in the mk1, as my header tank sits in the original position, unlike the mk4 setup
  18. Richard Mk2
    London / Bucks
    Cheers Jon :thumbup:
    I might do the same with my MK2. Any pics of yours by any chance jon ? :thumbup:
  19. Admin Guest
    in my build thread in the members section
  20. KentGTiKR Forum Member
    Lithuania
    Hello. I was offered to buy whole FMIC piping for a very good price, but it's 60mm diameter.
    So the question is: Is that diameter suitable for standard 1,8T AGU ? Won't be to large ?
