MK2 8v pulley removal
Discussion in '8-valve' started by RichardDarrenB, Aug 23, 2023.
  1. RichardDarrenB Paid Member Paid Member
    I'm trying to remove this pulley as someone has bought it. As you can see I have got the 4 x Allen key bolts out.
    Does the 19mm bolt also have to come out in order to get the pulley off?
    Tried heat and inpact gun but it just turns the engine. Need to lock it in position I guess, any tips on how best to do that?
    Thanks
  2. GVK
    It should come off with the 4 x allen bolts out, if you can tap out the threaded holes inbetween where you've taken the allen bolts out you can wind some longer m8 bolts in to act as a puller Big hammer required also...
  3. RichardDarrenB Paid Member Paid Member
    Cheers for the reply, I did what you suggested after reading elsewhere to no avail, and in the end I whipped the sump off and held the crank with a bit of wood, bolt popped right off.
  4. Savagesam
    Sounds like you need a bigger impact gun!
  5. RichardDarrenB Paid Member Paid Member
    Probably do to be fair. It's only a cheapo Clarke one, suspension top mounts is about its limit
  6. GVK
    Glad you got it off, put a new crank bolt in if you've undone it.
    if re-using the engine :)
    RichardDarrenB likes this.
  7. AndyBa Paid Member Paid Member
    Sheffield
    Are there different crank pulleys?
    IIRC my late 8v has a multi-point bolt which holds the timing belt cog on. I didn't touch that. The other crank V belt pulleys are held on by the 4 bolts into the timing belt cog and can be removed using a hub puller.
    The pic above looks different to what I remember. It was still a PITA to get the pulleys off tho.
  8. GVK
    Agreed on my old 16v the bolt was bi-hex , still 19mm.
    Probably just rusty AF making it look different
