mk2 golf air central locking. Pipe diagram..
Discussion in 'Security' started by Blue MK2, Nov 5, 2010.
  1. Blue MK2 Forum Member
    hello all
    I need some help with a mk2 golf central locking system (air type)
    I need to know how the air pipes run down the car from the drivers door.
    Any diagrams?
  2. jamesa Forum Junkie
    Abz
  3. neil kaye Forum Junkie
    england
    they dont run down the drivers door,the one in the drivers door is an electric one,which operates the pump
  4. Blue MK2 Forum Member
    got you! Thanks for that guys.
    I did look at that diagram at first and it looks as if their are vacume pipes which confused me.
    Just need the drivers door master actuator thingy then :thumbup:
  5. Munch471 New Member
    Just bought my latest Mk2 and the C/L isn't working. Discovered that the driver's side actuator was disconnected. When plugs in all the others work but not sure how to connect the metal rods from the actuator to the key and pin locks????
    The actuator has two rods coming from it which are connected by a metal block(???). Am I missing a bit of plastic?
    Any help would be appreciated.
  6. jamesa Forum Junkie
    Abz
    Posting a picture would help ...
  7. Munch471 New Member
    /Users/Munch/Desktop/2015-06-13 21.32.58.jpg
  8. Munch471 New Member
  9. Munch471 New Member
    I've managed to work out, i think, how to connect the rod and everything works BUT.......
    when I put everything back in place, the plastic connector that links the pull up pin rod, actuator rod and lock mechanism, slips off the lock.
    This means I can unlock the car with a key but have to pull the pin up manually to unlock all the other doors, boot and petrol flap.
    Super glue or have I done something, most likely, wrong?
  10. rubjonny
    you need to take the lock block off the end of the door then push the white lever thru the hole in the door, fit to lock block, then bolt it back up. the base of the lever is flanged and needs to sit outside of the door skin to stop it fallign off
    jamesa likes this.
  11. Texaroo New Member
    How do the window knob rod and central locking rod fit into this lever, are there 2 holes they slot into, my cent locking rod has come out but can't see how it fixes back.
    Regards
    Mark
  12. beetie
    beetie Forum Member
    leicester
    There are 2 holes yes
  13. rubjonny
    one thing that can happen is the retainer(s) snaps off which stops the rods falling out of the lever. its a little tricky hooking it all back together as well as you need to put the door pin rod on before you refit the lever otherwise you cant push it thru the hole in the top of the door. With the cl rod you can do it after the lever is fitted, just need to take the vacuum unit off the door then fit the rod to the finger then refit the vacuum actuator
  14. Texaroo New Member
    Thanks,see what you mean, will be able to angle the rod into slot then rotate it into hole, cheers.
  15. rubjonny
    yeah couple ways to do it. on mine when i was converting to central locking I fitted both rods to the plastic lever then pushed it all thru the hole, then put the lock block on :lol:
