Mk2 Golf Boot Install
Discussion in 'ICE' started by Richard Mk2, Jan 30, 2009.
  1. Richard Mk2
    London / Bucks
    Alright everyone..:thumbup:
    I just come across these pictures of a MK2 Golf Ice install, and i think it looks really neat and tidy... :thumbup:
    Just what i need in the back of mine as the box takes up the majority of space!
    Has anyone carried out this build before ? Just wondering if anyone would have the measurements of the build handy?
    Cheers!!!
  2. nealey Forum Junkie
    Audioscape make the sub boxes, not sure about the one to house the amp
  3. thegave Forum Member
    London
    Is it ok to screw my amp to the parcel shelf or will the supports/clips give out? i already have a fairly hefty pair of 6x9's hanging off it..
    the screws are mounted through mdf so there shouldn't be too much strain on the shelf itself
  4. G60. Forum Member
    Seychelles
    install looks very neat
  5. neil kaye Forum Junkie
    england
    looks nice but subs tend to need propper volume of air in the box,this one in the pic doesnt look like its going to have that,so could sound cack,for a start i cant see a port and it looks too flat
    thegave ,i wouldnt put the amp on the shelf,after a time it will start to bow
  6. StuMc
    50? 20` 47 N - 06? 57` 57 E
    Those Audioscape ones are properly designed to let the sub work to it`s optimum.
    Hence the 250 price tag...
  7. G60. Forum Member
    Seychelles
    StuMc, how are your enclosures coming along?
    Ready for the group buy? :lol:
  8. neil kaye Forum Junkie
    england
    in that case it will be a very good idea but an expensive one
    you could make something similar if you are handy with woodwork and knew the maths to work out the enclosure volume
  9. neil kaye Forum Junkie
    england
  10. StuMc
    Wondered how long it would take, before that was asked...[><] :lol:
    Once the 20v is done, I might, might, get round to doing it. ;)
  11. Cooper_Gti Forum Member
    How on earth can you say that?
    I bet that enclosure is no more than 0.5cuft, which to be honest, is just about enough for a sealed 8", let alone a 12".
    As said, subs do sound really crap unless they are in proper enclosures.
    A sealed 12", generally needs a minium of about 1cuft in order for it to sound good. Then if it were to be of a ported design then about 1.75cuft would be needed. Although this a very rough guide to give you an idea.
    My 2x12" subs need 3.5cuft each. You cant even fit 3.5cuft in a golf boot, let alone 7cuft!
    That audioscape install does look pretty good, but i would be very sceptical about putting a 12" sub in it!
  12. drunkenalan Paid Member Paid Member
    Leicester
    NEVER mount an amp upside down!!!
  13. thegave Forum Member
    London
    Ah. That sounds like solid advice.
    Is it to do with heat dissipation?
  14. neil kaye Forum Junkie
    england
    i thort 12'' subs needed 2.5 - 2.6 cubft,the box i have had run for years and the new on designed by 'dirtydubber' are both 2.5
  15. dirtydubber Forum Member
    That would be a sealed box with a fiberglass back shaped to fit into the space behind the wheel arch. Can be done DIY if you have the necessary glassing skills, but is difficult to accurately guage internal volume before building. As it a sealed box, you can get away with as little as 1 cuft volume, and sealed box designs are much more forgiving if you get the volume slightly wrong. If you want ported, you need a larger box. 2.5 - 3.5 cuft for a 12". Getting the internal volume right is absolutely vital for tuning a ported box or it will sound ****.:thumbup:
  16. StuMc
    I`m pretty sure Audioscape will know more about how sub enclosures work, than you or I...;)
  17. drunkenalan Paid Member Paid Member
    Leicester
    yes, amps arent designed to be hung upside down, they can melt things, trust me i know
  18. drunkenalan Paid Member Paid Member
    Leicester
    sub enclosures are sub specific, my rockfords can work in a box as small as 1 cu ft but optimum sound is at 1.65 cu ft the range is actually quite large upto 2.2 cuft and for a ported box the numbers are higher again dependant on port sizes and lengths
    My advice would be buy a decent sub and read the instructions, the manufacturers KNOW what they are doing.
  19. thegave Forum Member
    London
    can amps be mounted vertically then? i'm not sure what to do with it I don't want to put it flat on the boot floor incase i throw a bag on top of it and it melts i'm thinking under the rear bench but I can't imagine there being much ventilation down there either?
    any suggestions?
  20. neil kaye Forum Junkie
    england
    imo amps can be mounted anywhere,where there is a good air flow so the heat can dispurse,the reason i woulnt hang one on a shelf is like i said earlier it will end up bowing the shelf
