Mk2 Golf CE2 with ABF - wiring queries with pics
Discussion in 'Electrical' started by Greigzy, Jan 15, 2018.
  1. Greigzy Forum Member
    So, I'm looking for a little advice on my mk2 GTI with and ABF fitted. It's a CE2 car. There are 2 sets of cables I'm needing help working out where they go:
    1. 2 wires into a connector - comes from the cable under the battery. They are thick, 1 brown, 1 red/black. Seem to have a 12v feed when ignition is on. Can't work out where it goes.
    2. 3 wire missing a connector. Comes from the right side of the block, above the starter motor. 1 black, 1 brown/white, 1 blue/white. Thought it could be the fan or thermostat? It seems to have a 2 cable connector next to it that's white from memory.
    Any help would be appreciated.
  2. EZ_Pete
    EZ_Pete Forum Junkie
    Under Bonnet, nr Abingdon
    1. Is for the radiator fan, shown as T2i in this pic: https://www.dropbox.com/s/uolw9grz83e5e6l/Fan wiring.png?dl=0 Red wire permanent 12V from fuse, heading for rad thermoswitch (F18), on mating part. Brown wire to earth on fan module (V7), from chassis earth somewhere.
    Non-waterproof and often badly corroded.
    Josh Gateh and Greigzy like this.
  3. Greigzy Forum Member
    That's a great start, thank you.
    3 pin looks to be speedometer sender, it will run from the back of the round plug where the sensor loom joins the main bay loom if so
  5. Greigzy Forum Member
    It does indeed come from there, so that is a great update too. Thank you :)
