Mk2 golf g60 vacuum for servo
Discussion in 'Turbocharged, Supercharged or Nitrous !' started by J-dog G60, Sep 13, 2021.
  1. J-dog G60 New Member
    Hi I have an issue with the vacuum for the brake servo ,it’s connected to the inlet manifold above where the isv sits ,is this correct ?
    yep, whats the issue you're having
  3. davidut5 Forum Member
    Romania
    So no servo under boost? Does not have something like the 1.8T?
    there should be a non-return valve which holds vacuum in the servo
  5. J-dog G60 New Member
    Thanks for the reply’s ,I was getting positive pressure from the inlet manifold,I think it’s the idle screw ,throttle valve which I have replaced ,but didn’t adjust and was getting stuck
