Mk2 Scirocco 1.8t RWD
Discussion in 'Members Gallery' started by Mk2daz, Mar 25, 2020.
  1. Mk2daz
    upload_2024-4-2_10-43-8.gif upload_2024-4-2_10-43-8.gif upload_2024-4-2_10-43-8.gif Im well behind on the updates on this thing. Been chipping away at it since the last update.
    it now runs again, clutch is bled with a new slave cylinder, brakes been rebuilt and painted and bled, all the lights are working, horn working, gauges etc all working, its really not far away now from being complete.
    left to do:
    - fit carpet sections to floorpans either side of tunnel, and also boot floor, have made up templates for these just need to cut the carpet!
    - source and fit windscreen, struggling to find a second hand screen thats fairly local, looking like i’ll need to fork out for a new one, nae ideal!
    - restore the dashboard and refit it, plumb up the heater blower pipes and vents etc
    - fit boost gauge, map switch, brake bias adjuster etc, this will happen once dash is back in.
    - rebuild steering rack, and come up with a tie rod solution, currently binding on full lock
    - ball joint extensions
    - number plates
    - wheel speed sensor
    - seal up the sunroof delete
    - refit seats and harnesses
    - wheel refurb and new tires
    - MOT ready for summer etc
    Recent pics
    Cressa, Steffen and erreesse like this.
  2. Mk2daz
    Recent YouTube videos too, will try to get some proper updates and pics in soon as I'm a bit ahead of the update I just posted there!
    Steffen, erreesse and copeidge like this.
  3. Mk2daz
    I have booked this car into a local show on 5th May, this leaves me roughly 4 weeks to pull my finger out and get it finished and on the road!
  4. Tristan
    I grinned watching it sliding!
    Mk2daz likes this.
  5. Steffen Forum Member
    South Germany
    Stunning piece of work
    Mk2daz likes this.
  6. Mk2daz
    You and me both, it definitely needs a quick rack, but that can come in 'phase 2' :lol:
    Tristan likes this.
  7. Mk2daz
    I've been going pretty flat out on this car recently, even waking up early to work on it before the 9-5 slog , its all been worth it though as it now has a 12 month ticket!
    oldnick, erreesse, afbiker02 and 5 others like this.
  8. afbiker02
    Bury St. Edmunds
    Thats awesome, congrats mate
  9. Mk2daz
    Well its fully road legal now, taxed, MOT and insured!
    Took it out for a spin last night, its loud as f*ck, vibrates like hell, the tires rub on the arches, the gearbox is weeping oil slightly and the indicator relay is constantly buzzing - other than that though its ace
    was a fair bit smokey after a good run, turns out to be just the heat wrap on the downpipe baking in, nae oil leaks or coolant leaks yet!
    it’s definitely rough and ready, the pedalbox will take a bit of getting used to as the pedals are very close together, and you’ve to really press the brake pedal for the anchors to kick in, to be expected with no servo though
    The steering could be better, Porsche 924 rack is 4.1 turns lock to lock i think it is, its actually just a LHD mk1 golf rack and pinion, which Quaife happen to make a quick rack for!
    It also needs aligned properly, i’ve just done that by eye for now!
    erreesse, afbiker02 and daNpy like this.
  10. daNpy Forum Member
    NL
    Good job man! Now you can finalize the last details :)
  11. Mk2daz
    Made it to Crathes and back yesterday for its first show! Around 40 miles all in, only issue was a weeping gearbox, which after some quite high rev cruising along the motorway on the way back has turned into quite a decent leak!
    Going to remove the gearbox this week, reseal it wherever I can and try some expensive fancy oil in it (Redline MT90 I think), as it was whining and making a few strange noises. It actually sounds like a straight cut box haha
    Car had quite a lot of interest at Crathes and had a lot of people confused by what it was in the first place and what the hell was going on underneath it with the running gear - good day out [​IMG]
    copeidge, erreesse, afbiker02 and 3 others like this.
  12. Mk2daz
    As mentioned above the gearbox was a bit loud and 'clunky' feeling, it was also weeping quite badly too.
    So i decided to take it out last night and drain it of whatever oil I threw in it at the time.
    its been leaking from one of the 2 small blanking plates on the side of the box, think these are for accessing the selector forks.
    Anyway, its now resealed and ready to be fitted back up with 120 quids worth of funcy oil (for the diff too)!
    Heard nothing but good reviews around Redline MT90 so looking forward to seeing what difference it makes.
    afbiker02 likes this.
  13. costel1969
    Redline gets a lot of praise over on this side of the pond as well so I reckon you've made a very good choice with it.
  14. Savagesam
    Martin recommended it for me a few years back too!
    I’d like to have a drive of this car
