MK2 with ABF engine temperature gauge problem.
Discussion in 'Engines' started by Gazzmondo, Feb 28, 2024.
  1. Gazzmondo
    Gazzmondo Paid Member Paid Member
    Gateshead
    When I drive my Mk2 (ABF engine) from cold, the temperature gauge barely moves above zero. It should sit about half way when it's up to temperature as I understand. But when I let it sit and tick over, the needle moves to about three quarters. When it gets there, the dual radiator fans kick in.
    Should I be worried about the gauge not reading correctly when it's driving?
  2. daNpy Forum Member
    NL
    Well it looks like the thermostat isn't working correctly in the first part, but the fans coming on is strange. Afaik the sensor for the fans is in the radiator, which should be relatively cold when idling.
    I would check the thermostat nevertheless, driving a cold engine is not good at all.
    Gazzmondo likes this.
  3. rubjonny
  4. Gazzmondo
    Gateshead
  5. rubjonny
    Yep I agree with danpy thermostat would be my first thought. Worth getting another stat flange as well as they often warp and won't seal again, if you're using a MK2 rad and hoses a MK2 stat housing would fit best. The mk3 one can be a bit awkward, but if youre already adapted the MK2 hoses to suit the mk3 housing then get a mk3 one (or keep what you have if it's new)
  6. Gazzmondo
    Gateshead
    Ordered a thermostat and new housing from VW Heritage.
    daNpy likes this.
