MK3 Leon ST FR 400BHP Sleeper Project - Cupra Engine and DQ250 Swap
Discussion in 'Members Gallery' started by Mjj4, Feb 8, 2023.
  1. Skool New Member
    Nice project mate, let’s hope it all runs ok so you can raise a few eyebrows with it!
    Good to see your old Mk2 in the background too, still sporting the 928s
    Ps sorry not feeling the steering wheel, too furry!
    Mjj4 likes this.
  2. Mjj4 Forum Member
    Berkshire
    I really hope so, I can't wait for the first drive!
    Haha yes, still going strong. Not used the Mk2 much as I caught the sump on the way home from MOT last summer racing a M140i, and haven't gotten round to fixing it. When we start getting better weather I'm planning on using it a fair bit for work as it's the most economical car we own! I have some different wheels for it and am tempted to raise it up to a usable height so it's easier to drive quickly on our awful roads!
    I think I must have bad taste now as no one likes the steering wheel haha! I will see what it's like once the car is on the road!
    Not been up to much on the Leon the last couple of weeks as I'm fitting out both bathrooms at home. Mainly been messing around with different brake setups as I got hold of a load of Racingline brake stuff - 3 calipers, 2 fixed bells with no discs and 2 floating bells with 355mm discs. Turns out the Brembo 4 pot/TTRS setup does fit under the stock wheels with 15mm spacers, but I hadn't seen that someone had added spacers between the calipers and carriers - oops!
    So currently setup with the 355mm floating Racingline discs with TTRS calipers to check out the fitment, and it looks almost perfect bolt on if Reyland can make me some 370mm discs to fit the Racingline bells.
    Also got the exhaust back from being tig welded and that fits a treat, just need the Cupra ST exhaust bracket to fix it on properly.
    Raclingline bits and pieces:
    Older 6 pot monoblock caliper - 360mm on the newer 355mm disc
    Latest 6 pot stage 3 355mm caliper but only have one unfortunately!
    This was the setup I was going to go for, until 1 of the 4 bleed nipples snapped and I then snapped a torx bit in it! Haven't got that out yet.
    This was when I realised there were additional spacers between the caliper and carrier on the TTRS setup, so chucked one on to check the offset with the disc and inner pad clearance which is perfect.
    So going to try and get some 370mm discs made and go with this setup as I think it will be the most reliable caliper wise.
    Right hand exhaust outlet sorted which I'm very happy with.
    Hopefully ECU's and DQ250 de-immobiliser will be sorted next week, so I better pull my finger out this week if it stops raining!
  3. Mjj4 Forum Member
    Berkshire
    It's been a while, but progress has finally been made!
    2 Sunday's ago I loaded the Leon onto a truck and took it to the wizard that is Toyotec to have the gearbox de-immobilised.
    Exhaust shot - just need to trim the end off from the downturned tip as it's visible from behind.
    Things went well and after an hour or so the Leon moved under it's own power for the first time in a while!
    The dashboard was lit up with a whole host of errors.
    - Horn didn't work
    - ESP fault
    - Hill start assist unavailable
    - Auto hold unavailable
    - Parking sensors not working
    - TPMS unavailable
    - Front assist unavailable
    After some VCDS coding I managed to get most of the faults sorted
    This was all down to the VAQ being connected to the can-bus but not being coded in. Once that was coded in, everything else started working.
    Almost a clear instrument cluster
    Off to get MOT and tracking done so I can at least drive it whilst getting everything else sorted. I've only driven it in the damp on the Bridgestone S001 tyres that it came on, and it is lively to say the least!
    So finally it's road legal and all working bar some minor niggles - there's a gearbox DTC that needs deleting, it needs a service and the front sensor CP needs removing, then it'll be error free and onto the nice to have things, like Cupra Drive Select, virtual cockpit etc...
    Next I took the Leon to Seat for the front sensor to have Component Protection removed as the car didn't have a front end on it when I bought it. They carried out all the test plans available on ODIS for the front sensor, which is now CP and fault free! This means I now have working cruise control too. Only faults left are the gearbox dtc, key battery and service light. Not bad!
    Body shop next I think!
    Current list to do:
    - Finalise front brake setup
    - Refurbish front brake calipers in black
    - Fit right hand exhaust heat shield
    - Fit 370mm disc guards (bought from a TTRS part no and they don't fit!!)
    - Fit Virtual Cockpit (purchased) and MIB2 unit with MOST port (if PFL unit is compatible)
    - Get CP removed for virtual cockpit (if required)
    - Try and code the car to remove any faults (nearly there!)
    - Send to body shop
    - Try and code in Cupra mode, ESP off, and add a physical ESP button - I think the Cupra Drive Select may be an issue as I think it's something to do with the MIB software and not a coding option, but we will see.
    - Re-trim the headlining in black as I'm not a fan of light colour headlinings.
  4. GVK
    Awesome progress.
    Mjj4 likes this.
  5. Mjj4 Forum Member
    Berkshire
    Minor update. I dropped the Leon at the body shop today. There's a fog light connector for the NSF that I've never seen, and ideally wanted to sort this before the front bumper gets painted so I don't have to take it all apart again once painted, but I decided I'd worry about that later and I'd rather get it painted for now and worry about the fog light wiring later. The only other thing is to sort the washer pipework as the Cupra washer bottle is on the drivers side chassis leg due to the additional radiator.
    I should probably post this next bit in a different forum, but I've been looking into the ESP settings, as this car only had the option for ESP on or ESP sport, both of which are very intrusive. I was surprised how little information is about this online, unless the Cupra comes factory with the full ESP off option in the MMI?
    Either way, I coded the ABS module to allow for "ESP off" to be selectable from the head unit (I don't have a physical ESP button yet).
    This was done by ABS module, long coding byte 29 and changed from 03 to 06.
    I thought this was going to be it, full ESP off and no assist from the car at all - but obviously things aren't that simple. Did a bit more research and it appears that there's a further assistance called "starting vibration reduction" which is supposed to limit power at lower speeds to reduce wheel hop. This is found in the ABS adaptations, unless like my Leon being a 2018 you don't have this option. It appears that VW have renamed this "rough road optimisation", and the purpose is to cut power/limit torque when you're losing traction over bumpy surfaces. It seems this is picked up in wheel hop scenario's though, as I was getting a fair input from the ESP even with it off.
    So I de-activated rough road optimisation in the ABS module adaptation channel and this has solved it for me. I can light up both front wheels to the limiter with no input from the car, or go back to ESP sport and have some intervention, or back to stock with ESP on. Much better!
    Next to work out is how to have Cupra mode, as currently I can't adjust the VAQ settings as it's not showing on my head unit.
    Last minor thing, I managed to get the head unit screen to show a Cupra ST finally!
    Hopefully it will be one colour soon, here she is currently, sporting the correct shape brand new bonnet.
  6. Mjj4 Forum Member
    Berkshire
    Well it's finally in one colour! This is exciting for me as I purchased it with no front end, so for it to look like a finished car (nearly) makes it all feel much more worthwhile.
    I misplaced my pot of front bumper bolts, so got a whole new set from TPS but still need to fit some of these, then get the front brakes sorted as it looks awful with the red Cupra calipers.
    Toyotec, Skool, erreesse and 2 others like this.
  7. Mjj4 Forum Member
    Berkshire
    Brake update - I sent off one of my Racing Line bells and 355mm rotors off to Reyland Motorsport to see if they could machine me up some 370mm discs to suit my existing bell, and they measured and made me a pair of plain 370mm rotors that are just the job. I can't thanks Jenny and Martin enough for their help and customer service. Due to costs and that I'm not planning on tracking this car in the near future, I went for straight vane compared with the fancy curved vane Racing Line discs, and plain finish for the sleeper look (as much as can be with huge discs).
    Just need to paint the calipers and either modify the TTRS dust shields to fit, or cough up again and buy RS3 shields. Hopefully paint them soon, just weather dependant unfortunately! Due to the awful weather I built up a spare hub with the disc, caliper and pads to check fitment.
    Outer pad/disc clearance
    Inner pad/disc clearance
    You won't have really noticed as I still haven't cleaned the car since it's been painted, but the right hand exhaust tip was visible below the rear diffuser, so I cut this down and now it's completely hidden. You can still see the exhaust running both left and right as it passes under the rear subframe, but it's subtle and I quite like it. The left exhaust tip is starting to look more subtle as it's getting dirtier too.
    I'm having some issues with the VAQ - which I'm not overly surprised about to be honest. I have 4 "missing message" errors on VCDS for the VAQ, all of which I believe are related to the ABS/ESP, and therefore the ABS coding. I haven't had much time to investigate this, but the coding between the donor Cupra ABS pump and the FR are completely different - the FR is about twice as long, I guess from being a facelift. My first port of call will be to look for a facelift Cupra 290 ABS coding online and try and compare that with my FR coding.
    It may not help that I don't have a Cupra mode on my drive select, meaning I cannot set the VAQ settings on the head unit. I have the Cupra donor MMI unit so I will try that route and see if I can get that working.
    I did some checks on VCDS for the VAQ and it says that basic settings have not been started, so I carried out basing settings which completed successfully, but it still says they have not been started.
    Once I get the VAQ sorted, I think I may go down the Garrett Powermax stage 1 turbo route, possibly with a HPFP, with an aim of a safe 450bhp. It seems a waste to have fitted all of the supporting hardware during this swap, but to only achieve a few more ponies than a basic stage 1 with full stock hardware.
    erreesse and dragonfly like this.
  8. Mjj4 Forum Member
    Berkshire
    Nearly there with the brake setup now! I fitted my huge concoction of brake parts:
    - Aston Martin DB9 Calipers with balance pipes reversed (these were from a VBT kit)
    - HEL braided lines
    - Audi RS3 carriers
    - RacingLine floating bells
    - Reyland Motorsport custom machined 370mm plain discs
    - VCDS coding for 370mm setup
    I had actually ordered and received VHT gloss black, clear lacquer and Brembo decals to re-finish the red RS Brembo calipers I had been using to mock everything up, and I was planning on cleaning them up, sanding them down to paint them over the last week or so, but was waiting for dry weather as I don't currently have anywhere inside suitable for painting at the minute. After receiving all the parts, a full Aston Martin Vagbremtechnic setup came up fairly locally on Marketplace, with little use, and nearly new 345mm discs and Ferrodo pads (need to check this when I fit the disc guards). I got this set at a great price, just missing the carriers, which I don't need with my RS3 carriers and new Reyland discs - although it would have been a great value for money kit if I hadn't just spent more than the whole kit on the Reyland discs, as I could have just bought the 345mm carriers cheaply when they are back in stock!
    Although the Aston Martin decals aren't my favourite thing, I was drawn to having factory finished black calipers, and the fact that I could bolt them straight on and go without any issues. If I choose to re-finish them to have Brembo decals in the future, at least they're black to start with, so no chance of any red coming through if chips occur etc... I'll either sell the red RS calipers as a complete bolt on with with the 345mm discs and brand new carriers when they're in stock, or perhaps re-finish them in black with Brembo logo's as I have all the paint now, and see how they come out.
    Here is the kit:
    Here's the Brembo/RacingLine/Reyland motorsport concoction all installed:
    Nice and snug under the stock wheel with a 15mm spacer - I think 12mm would work, but 15mm front and 20mm rear suit the stock wheel setup and was how I had it with the stock brakes anyway.
    Should really clean the car!
    Lots of brake parts to clean/re-finish and sell now!
    Next up will be brake disc guards, Just need to modify my TTRS disc guards, or buy later RS3 guards now, and i think I'll be done brake wise (hopefully anyway!)
    After that the list looks something like:
    Current list to do:
    - Wash and machine polish whole car
    - Investigate slight exhaust blow
    - Sort VAQ issue
    - Fit sound deadening to boot floor, and golf estate spare wheel well carpet
    Then longer term things:
    - Upgrade audio with Seat Sound
    - Fit reversing camera
    - Do a black/alcantara roof lining conversion
    - Try and find Cupra Estate alcantara door cards (facelift)
    - Change seats to something nicer & heated
    Seems never ending!!
    If anyone is interested in the future about doing the Sub8 or Brembo 370mm conversion, here is the ABS coding options for Byte4 in the ABS module:
    As you can see, 370mm front brake setup requires Byte4 to be C4. You also need to mirror this in Byte17, which is 23.
    Byte 4 - C4
    Byte 17 - 23
    Not sure how much difference this makes pedal feel wise, as I did the coding at the same time as the hardware change. But it likely has an effect on the XDS and ESP, which from a safety point of view could be seen as significant. If the ESP isn't aware of the larger front brake setup you're running, then it could potentially make things worse when it applies pressure to a single caliper in a spin scenario, and the brake effect is considerably different than the ESP algorithm dictates.
    This is my opinion though and should be taken with a pinch of salt, its not like you're telling your ABS coding what brake pads you're running, which can and does also have a dramatic effect on your braking performance!!
    Toyotec, erreesse, GVK and 1 other person like this.
  9. Mjj4 Forum Member
    Berkshire
    2 Updates:
    - Still haven't washed it yet
    - Turbo failed on Sunday
    Now I'm pretty sure the issue was turbo overspeed that caused the failure, contributed by both the free flowing exhaust setup I'm running, along with 7,000rpm for an extended period of time in a wet 4th gear wheel spin with traction fully off. I think its likely that the shaft has snapped. To be honest I haven't even looked at the car since Sunday, as the weather has been pretty poor and when I opened the bonnet to remove the inlet to have a feel, it felt like the wind was trying to rip the bonnet off.
    I was planning on upgrading the turbo when I had ironed out any issues with the car - (mainly the VAQ to be honest) and keeping the low mileage IS38 for my spare 1.8 EA888 engine. That plan is now scuppered, so I have to decide whether to go down the route of a Garrett Powermax and Ecotune map, or similar setup. Or whether to risk buying a second hand IS38, and then having to do the job over again later on down the road. Why did this have to happen in winter?
    I also wanted to start on improving the interior soon, and as everything costs money I need to decide whether the turbo/mapping route is the best thing to do cost wise at the moment, vs another IS38 and other bits that I had planned.
    Hopefully get the car in front of the garage next week, have a plan/some parts and can strip it down.
  10. Mjj4 Forum Member
    Berkshire
    So an update on 2 fronts - firstly engine/turbo.
    So I finally decided to see what had gone wrong with the Leon following suspected turbo failure, and what a failure it is!
    Certainly not good! I turned the car off as soon as it lost power and erupted in smoke, and haven't started it since, or even moved it onto my drive for that matter. Before deciding what to do about the turbo, I borrowed a cheap borescope camera and put it down each cylinder to look for any damage to the pistons/cylinders. To be honest the camera was pretty useless and all I could see was that the top of the pistons were clean with no real carbon build up - just the same as you can see when you shine a torch down the spark plug hole. Regardless, it looked clean which was a good start, so I carried out a compression test.
    The manual states you need to be at minimum 30 degrees, and with 12.7v on the battery. It was about 5 degrees, and the battery was getting flat by cylinder 4, but I'm working with what I've got roadside!
    Factory Specs
    New specs -160-203psi
    Wear limit - 101.52psi
    Max difference - 43.5psi
    Cylinder 1
    Cylinder 2
    Cylinder 3
    Cylinder 4
    So all 160psi or a touch over, my gauge isn't holding values for some reason, so it would get to around 175psi before dropping back on the next revolution when I'd stop turning the engine over.
    Plugs look a good colour too, although I had installed cylinder 1 before thinking about taking a picture!
    Also had to modify a 10mm spanner to be able to get the earth's off of the coil packs
    So the compression test results are very good, meeting the new specs, from stone cold with a less than great battery. Hopefully that means any debris from the compressor wheel that could have caused damage has been caught by the intercooler.
    Next step is to decide what to do turbo and map wise going forwards. As the car is off the road, this is somewhat of a priority for me to decide!
    That brings you up to speed with the mechanical side of things, next up is the first step of the interior.
    So FR spec cars come with the red stitched seats, steering wheel and gear gator. I'm not really a fan of this, especially on a purple car. I wanted the facelift Cupra carbon bucket seats and matching door cards from an ST, but they are hard to get and demand a premium too, so I looked around at what other MQB seats are nice. I looked at Cupra Formentor and Ateca, but not a massive leather or orange stitching fan (a Cupra brand favourite) for the same reason as the red stitching. The perfect seat for me is the Mk8 Golf R-Line bucket style seats. When a set came up from a 2022 14k Golf R-Line that had a pylon fall on it in the recent storms, I had no choice but to buy them, even with the car stranded with no turbo! The fact they're heated which is an option was the cherry on the top for me - so heated seat retrofit will come too at a later date, although I've not seen anyone get them working in anything other than a Mk8 yet.
    Here they are:
    Compared with stock FR seats
    Fronts fitted
    Rears fitted
    The airbag plugs are the same too, which I've never had in the past with swapping seats before in VAG vehicles.
    You'll all be happy that my steering wheel "re-trim" will have to be changed as it has red stitching, so when the cars up and running I may get it trimmed professionally along with the gear gator now I have nicer seats.
    Black roof lining of some sort is on the cards too as I'm not a fan of light roof linings.
    Toyotec and erreesse like this.
  11. costel1969
    Those seats look the business.
    Mjj4 likes this.
  12. dodgy
    Missed a lot of the updates, but great, shame about the turbo, but it just accelerates the upgrade I suppose.
    Worst thing in my FR estate is the seats, half leather with cloth centre, red stitch is fine as its a grey car, love the heating, but it's the fabric that marks so easily, if you get in with rain on your clothes it seems to stain them, I had mk1 LCR recaro seats in my inca and they were similar and showed every tiny mark.
    Have considered S5 seats or alcantara centres in 5f ones.
    We're your golf ones from an estate or hatch, and did it fit straight into the leon, what about the rear seat fold from boot?
    Mjj4 likes this.
  13. Cressa Paid Member Paid Member
    Just had a complete read of this thread, fantastic work.
    Mjj4 likes this.
