My efr 7064 big turbo build, will be pic heavy
Discussion in 'Turbocharged, Supercharged or Nitrous !' started by 10mm socket, Nov 30, 2016.
  1. 10mm socket Paid Member Paid Member
    Yes your correct toyotec, I rang mr walker and he told me it goes on the plenum.
    Toyotec likes this.
  2. notenoughtime
    Essex
    So I was correct to start with?
  3. 10mm socket Paid Member Paid Member
    And?
  4. Toyotec
    Carey, your thoughts, after Nige's question in post 36 and an exchange between myself and 10 mm socket after, where I sort the clarify map sensor positioning in the air charge path, were correct yes :thumbup:
  5. notenoughtime
    Essex
    I was just winding Leroy up, he enjoys a bit of banter :thumbup:
    10mm socket likes this.
  6. 10mm socket Paid Member Paid Member
    Haha! Yes, it makes for a better day.
  7. 10mm socket Paid Member Paid Member
    I got all my meth injection set up and wired in yesterday, oooooh! It certainly makes a deep rumble through the chassis, ''tis like sitting in a vibrating massage chair.
  8. notenoughtime
    Essex
    When is it going to the rolling road? And when is it going on the track mate?
  9. 10mm socket Paid Member Paid Member
    It's booked in for mot this Saturday, 100 miles of running in and then off to emerald hq for mapping session.
    notenoughtime likes this.
  10. 10mm socket Paid Member Paid Member
    Truck didn't get mot test carried out, tester refused as it was burning oil. I drove back home very disappointed but understood...it was quite bad the smoke. Now this seemed to appear from last night( well got worse) it's always smoked a little since I got the engine running, but put that down to the rich map it's currently got.
    Anyway I found the turbo oil return line kinked, I haven't carried out any remedial work since this morning, as I've been busy today. So fingers crossed it's just this.
    I'm hoping it's not rings( but carried out compression test last week 180 psi)
    Or stem seals ( unlikely they're new)
    Or turbo seals ( no oil in the boost pipes whatsoever)
    Or bores glazed ( wasn't last week when I saw them from the underside, when sump was off)
  11. notenoughtime
    Essex
    What's the latest mate?
  12. 10mm socket Paid Member Paid Member
    I'm all road legal and got the boring task of running in with minimal boost.
  13. 10mm socket Paid Member Paid Member
    The smoking turbo was sorted, the culprit was a kinked oil return line
  14. 10mm socket Paid Member Paid Member
    Mapping session booked for 23rd August at John sleath in Yorkshire.
  15. possle Forum Member
    Nottingham
    Need some vids of this monster
  16. notenoughtime
    Essex
    Come on what's the latest? How did rolling road session go?
  17. 10mm socket Paid Member Paid Member
    420 for now, boost solenoid is faulty ....
  18. 10mm socket Paid Member Paid Member
    Hey guys, considering having my head o ringed as Im heading into 2bar boost territory with a 100 shot of nitrous. Anybody on here had their head o ringed and offer some advice?
    Thanks
  19. 10mm socket Paid Member Paid Member
    Can nobody help on this?
    Thanks in advance
  20. notenoughtime
    Essex
    Hey hope all good?
    Did you get any more power once the boost solenoid was sorted?
    Regarding o rings not necessary as blocks are stiff anyway what about a girdle to hold the bottom end in?
    You have ARP head bolts yes? (Obviously)
