No power to passenger door - any help?
Discussion in 'Mk4' started by SafferYork, Feb 2, 2017.
  1. SafferYork New Member
    Hi all.
    My 2002 GTi has got absolutely no power running to the passenger door - central locking doesn't work on this door, window doesn't work from the door switch as well as the drivers switch, the electric mirror doesn't work on this door.
    The only thing actually working on this door is the speaker.
    Any suggestions from anyone? I've checked the wiring in the rubber boot between the door and the car body, and they all look to be in good shape.
    Thanks all.
    ideally get diagnostics on the CCM module, it might tell you wahts up. you can also see in vagcom if all the window motors are accessible via the can-bus
    the live feed comes from the same fuse as the driver side so its not that, if you can get to the 10 pin plug at the a pillar where the door loom connects check you see 12v on pins take the motor off and check you have 12v on pins 3 & 8, and earth on pin 4. If that checks out have the door motor off and check for live at pins 19 & 20, and earth on pin 10.
    If thats fine look at the can bus twisted pair orange/brown and orange/green, there is a signal down here from the CCM module which tells the motor to switch on and passes comms between them
  3. MUSHY 16V
    aberdeen
    It's worth making sure it's plugged in properly at the door locking module as if it's not non will work
