OEM MK4 management wiring => Mk1/2/3 harness install FAQ (Now with added dieselness!)
Discussion in 'Engines' started by rubjonny, Nov 8, 2013.
  1. rubjonny
    Pin 8 is unused on aum, it would be coilpack power from ECU relay on Agu engines, or fuel pump power for injectors on some 5/6 cylinder engines
  2. v3n0mou5 New Member
    Ah great thanks!
    If i combine pin 5 and pin 8 from the t14a to z/1 isnt the load too high?
  3. rubjonny
    I wouldn't do this on an agu, what I do is join the t14a/8 and t6/1 to a fused feed from a relay to power both ECU and coils
    But since you have an aum t14a/8 is unused anyway so no need to worry. Check out the sensor loom side of the plug to see what wires you actually need :)
  4. v3n0mou5 New Member
    thanks il check that!
  5. nickosy New Member
    Jonny, the mk3 a/c pump bolts up the exact same as the mk4 type.
    To simplify the swap s&p automotive sell a billet a/c adapter to make the mk2 a/c lines connect up to a mk3 compressor.
    Only thing I’ve needed to do there was change the plug over from a mk4 type to a mk3 square plug.
  6. frenchyy New Member
    Hey mate, followed this guide for my Mk3 conversion and have run into an issue that prevents it from running.
    The car will start fine and start to idle but then stall out within ~10 seconds, the only ways to make the car stay alive is to unplug the throttle body or using starter fluid. Since the car will run on starter fluid that leads me to think that it's an injector firing issue
    There's no fault codes on VCDS
    So far I have tried/confirmed
    - tried different tb, no change
    - replaced fuel pump + filter + regulator
    - confirmed fuel pressure at rail with mechanical guage
    - replaced crank sensor, no change
    - tried starting with maf unplugged, no change
    - tried starting with map unplugged, no change
    - tried capping all vacuum ports (brake booster, fuel reg, dv and pcv), no change
    - confirmed ecu pins 1&2 have ground
    - checked all grounds while cranking/running
    - when the cars does idle it's making around 18-20hg of vacuum which suggest no vacuum leaks
    Keen to hear what you think, thanks
  7. Neal maharaj New Member
    Hi thanks for this write up.. I’m building a harness for a non VAG car using the mk4 1.8t as a donor drivetrain and harness. I’m a little stumped on the ac.. I’m looking for the idle up/ rpm bump up pin out. At this time I don’t plan to use the mk4 fan module etc. Can you advise on which wire(s) for rpm bump? Thanks!
  8. rubjonny
    frenchyy - any luck? sure the immobiliser has been defeated properly? also if you swap the fuel relay for a std switched type (17/18/100) or jump the socket does that help?
    Neal: pretty sure its T10/8 you need for idle increase, based on the various diagrams I've looked at. for example on the MK4 manual AC this is the 12v output from the AC switch to FCM and ECU so that should do the trick
  9. Neal maharaj New Member
    Thank you sir! Will update my results.
  10. nickosy New Member
    How has everyone wired up there radiator fans when using the alloy radiator and aftermarket fans?
    3pin 2speed fans oem off mk2 gti 8v with air conditioning
    I’ve spit the grounds to feed both aftermarket fans
    Then connected on one both red/back and red white wire to the power fees for 1x fan and the red black only for the other.
    I’ve jumped the terminals to the coolant temp sensor in the radiator and they manually turn work when you jump low and high speed however put a new sensor into some boiling water and the fans don’t turn on at all.
    Both fuses on fusebox positions #19 and 13 are ok
    I’ve got the after run temp sensor off the mk2 installed also.
    If I cycle the ac fans they turn on. Just not when getting up to temp
  11. rubjonny
    If the fans work when you jump the fan switch then all is good wiring side, either the replacement fan switch is dead or you didn't get it hot enough
  12. Danielson32 New Member
    Hi Guys,
    First of all I just want to say thanks so much for everyone that’s put time and effort into this thread. Especially Rubjonny.
    I am currently doing my BAM loom and the engine is to be run on a rwd gearbox without the tt dials. I thought I had everything figured out although after hours of research in these threads I’m currently worried about the ecu not seeing signal from the VSS causing a low rev limit.
    Has anyone managed to work around this?
    I know there is a mk2 escort running on a rx8 gearbox using oem management so it must be possible somehow.
    Any info is much appreciated.
  13. rubjonny
    what car is it going into? for example MK1/2 Golf have a VSS output option from the cluster even though they are analogue, the GTI models have a speed sensor for the MFA and non-GTI also had the option as it was required to run the cruise control system plus some ECU need it also
  14. Danielson32 New Member
    Thanks for the reply,
    The engine is going into a Volvo, using a rx8 gearbox. Does the vss change the map even if you’re not using limiting power in certain gears?
  15. Prskii New Member
    Hi @rubjonny first all the best in the new year.
    I'm in a loop of bad luck lately and I would appreciate if you or anyone else could give me some useful advice on my current problem with 1.8T mk3. Ok so I did a swap ( AGU, DBC ) as per your guide and everything worked flawlessly for the last 6 months. I'm gonna try and explain everything as short as possible with all of the important details that could help to resolving the issue.
    2 weeks ago or so, my RPM needle suddenly started to jump around on its own, it would bounce back and forth randomly and than it would work like normal for a bit than again madness of randomly jumping around. I thought nothing of it as day before it was really heavy rainstorm so I thought maybe water got somewhere and is fucking up reading of the gauge. Shortly after needle bouncing was paired with oil light flashing and buzzing. So first thing I checked is oil level, which was good, than I checked wires to oil pressure switches which commonly get broken from high temps but they are good as well. Ok never mind, I don't have time for that now so I let it be, it is mk3 after all.
    Fast forward last week, I came back from work, everything fine while driving, as I said motor has been ultra good since the swap, pull in my parking space, put it in neutral to let oil cool down a bit before turning it off and suddenly it starts idling really bad ( my gut feeling said that its working on 3 cylinders only ). I shut it off, try to start it, cranks but no start. I let it cool down a bit, came hour later turned on like nothing happened, idled good, I let it warm up a bit and took it for a spin. 20 meters later starts stuttering, I need to keep gas pedal down to keep it alive. It did manage to shut off while I was parking, I barely managed to start it and it just started smoking like crazy from exhaust, everything smelled like petrol so I assumed either bad spark plugs or injectors over fueling.
    I connected it to read fault codes: Cylinder 2 injector shorted to GND, intermittent. Pulled off cyl. 2 injector plug, both pins are grounded. My first thought w as there is something wrong with wiring since it goes through T14 plug to ECU. Disconnected everything and pulled out whole loom to check if something is shorting out but everything is fine, not even plug pins are corroded ( btw this is the best loom condition vise I've seen, especially regarding injector and coil wiring ). After plugging back everything in cranks but no start, RPM gauge and oil light still doing its own thing ( dk if this is connected to the issue but yeah ).
    Next thing I did was pulled out ignition coils and spark plugs. Valve cover gasket is pretty bad since its leaking oil into cyl. 2, and sparkplugs are not great either ( I knew this and was planning on changing gasket and spark plugs ). I cleaned everything, checked if I have spark, yes, good blue spark. I checked if I have fuel, yes ( spark plugs get wet after cranking as well ), I even checked if its in good condition and flammable, yes. Tried few different fuel relays. Put everything back together, still cranks but wont start.
    Now I need your opinion on what could be the cause and not to spend all my money on things that wont solve the issue.
    Timing jumped a tooth and not igniting at right moment? Bad knock sensor? Bad ignition module? Cam position sensor?
    Sorry for the long ass post.
  16. rubjonny
    Daniel: Good question, there are those who say ecu doesnt care about VSS, some say you can code it out, and some say ecu has speed based maps :lol:
    The VW gearbox puts out just over 6k pulses per miles, or about 7 per wheel rotation. you could put on your own hall sensor to pickup off the CV joint bolts, that would be close enough
    Prskii: the rev counter thing immediately makes me think of crank sensor, but maybe its unrelated cluster fault. i would start by making sure G1/5 has a good earth, originally it would go off to the head but you can just earth it inside the car. the mk3 clusters do just go faulty though...
    did you try swapping the coilpacks between cylinders after clearing the fault, to see if the problem moves?
  17. Prskii New Member
    G1/5 is grounded to ground ring under the dash, and it worked properly last 6 months so I doubt its that. Faulty cluster could be cuz it started to act weird days before car stopped working. Where does it get RPM signal from on 1.8T engine? Oil light flashing I assume its due to incorrect RPM reading and now car not being able to build the oil pressure up since it just cranks.
    No, that was my next thing to do, and will see if a friend has spare ignition module to rule that in as well. I assume its one of above mentioned sensors that's faulty just need to rule out one by one.
    By looking at other people posts on forums for similar situation, lot of them changed almost everything to get it to work and didn't quite get what actually was faulty.
  18. rubjonny
    rev counter is the its the brown/green wire from the orange plug you spliced to G1/12 :) its fed direct by the ecu, and if the crank sensor starts to fail a dappy rev counter is sometimes the first sign of it
    ignition amp is a good plan, especially if its just hanging about in the engine bay. it needs good airflow to stop it failing, people find chucking it in the scuttle does the job if the factory 20v airbox isnt used
  19. Prskii New Member
    Update,
    so my friend has mk3 1.8t AGU as well working perfectly so we used his car as a part tester for my shitbox. Firstly we tried his ignition amp, no difference. Than we connected it again to scan codes, now it showed "Injector shorted to GND" on all 4 cylinders, which we expected because fuel smell was really hard after trying to start it. Next we removed coils and plugs, disconnected injectors so that they not fire, to crank it to empty all excess fuel from cylinders and oh geez, we surely didn't expect approx. 3-4l ( yes liters ) of fuel just shooting straight out from cylinders all over us. So we swapped over his fuel rail with injectors to test if mine are done, but same thing. Both his and mine injectors have really good spray pattern but they are just over fueling, and we found out that cyl. 2 injector ( which was originally only code we had ) is spilling fuel already after key is just in ignition on position which is weird. Now for some reason we haven't tried his ECU on my car but my ECU on his car and his car fired up straight up without any hesitation or problems.
    Next thing was to tackle wiring to recheck everything regarding T10a plug since its him who delivers power to injectors and coils. This is how it is connected to mk3 fusebox:
    - Pin1 -> G2/10
    - Pin2 -> G2/4
    - Pin3 -> G1/11
    - Pin4 -> G2/3
    - Pin5 -> Z/1 ( 10A fused )
    - Pin6 -> Z/1
    - Pin7 -> Battery GND
    - Pin8 -> ECU relay pin 87
    - Pin9 -> Battery GND
    So since injectors are getting short to GND code, I immediately checked Pin5 and Pin7 and they are shorted. I unplugged everything from fusebox and they weren't shorted anymore. So by elimination method I plugged back one by one plug until I got it shorted again, and ofc it was the last one, which is the M plug aka fuel tank wiring harness. Since it was late we left all of it there to continue tomorrow ( battery was disconnected ). Does this give any more insight to what could the cause be?
    EDIT: he just called me while I'm writing the post that car is running ( roughly, but runs ) with all 4 injector plugs disconnected, and without hose from IC to throttle body ( weird cuz it never could idle without IC connected ), he connected his ECU ( 100% working ) this time.
  20. rubjonny
    if you check for earth on the fuel pump circuit you will find it, as there is a path to ground through the fuel pump plus the lambda and maf heaters. the fuse would have blown if the circuit was actually shorted to ground so its not that.
    since injector 2 is dribbling fuel with ignition on what this suggests is the earth pin on that injector is shorted to ground, so the injector is stuck open. how it works is you have live to all 4 injectors via the T10a plug, and the ecu pulses the earth to actually open the injector. so the next step is have a look at the injector wiring back to ecu
    also T10a/3 should be empty, instead the speedometer sender wire back to G1/11 should be wired to T10a/10? if the speedometer actually works, then no need to worry though :lol:
