Outside temp sensor compatible part number?
Discussion in 'Electrical' started by black_cabbie, Jan 17, 2024.
  1. black_cabbie Forum Member
    Belgium
    I have just finished the installation of the digifiz in a MK1 Cabriolet and I am looking for the outside temp sensor.
    Its a bit difficult to find the proper one (357919379A) so I was wondering if one from MK4 golf will work? I could play with the ohm rating to it to read as close to the real temp as possible, I am just not sure about the ohm range.
    digifiz uses the same sensor as the mk1/2 MFA cluster. 357919379A would be incorrect as its the mk3 golf version which has a different resistance curve
    you could use Golf G60 and early corrado/passat 357919379 though, probably harder to find than the original mind
