Pierburg 2E2
Discussion in 'Carburettor' started by paulvandyk688, Oct 26, 2014.
  1. What can be wrong with this part spring inside is ok, but gums outside i dont know[​IMG]
    What is the name of that part?
  2. EZ_Pete
    EZ_Pete Forum Junkie
    For the 3-point unit to function as designed, each of the rubber O-rings must form a gas-tight seal. If it seems that the O-rings are original, they are likely to be hard and inflexible, so replace them. I don't know what the correct sizes are, you may have to experiment. I don't remember having much trouble finding some that worked when I refurbished my 2e2.
    Good luck. :)
  3. thank you pete, i think to replace them i think this is the reason for droping my rpm on hot engine
  4. what is the dimension of o ring any know?
