(PLEASE HELP) 1996 Golf GTI VR6 AAA, crank, no start.
Discussion in 'Say 'hello' in here.' started by rudy_nyc1, Jan 20, 2018.
  1. rudy_nyc1 New Member
    Florida
    I have a 1996 Golf GTI VR6 AAA, it cranks fine but will not start. fuses good, new cam sensor, good crank sensor, extra ECM, good battery, and new gas pump. After doing some tests I noticed that it had 2 dead circuits that are necessary to start. ECM relay and the (FPR) fuel Pump Relay both missing the negative triggers to activate. I have scanned the engine and I have a 5 codes, 2 of the codes are the ones preventing it from starting. If I add a negative trigger to the 2 relays they will activate with no problems but will not start. BELOW I HAVE PROVIDED THE SCAN REPORT FROM VCDS ROSS-TECH...........CAN SOMEONE HELP ME PLEASE, PS: I AM NOT A MECHANIC BUT I CAN HELP MYSELF, this is just a restore project car for me. THANK YOU AND HELLO TO ALL MEMBERS OF THE GROUP I AM NEW HERE.
    VCDS Version: Release 12.12.0 (x64)
    Data version: 20130910
    Sunday,07,January,2018,20:00:49:62939
    Chassis Type: 1H - VW Golf/Vento III (1992 > 1999)
    Scan: 01 02 03 08 12 15 25 41 56
    Address 01: Engine Labels: 021-906-259-AAA.lbl
    Part No: 021 906 259 A
    Component: MOTRONIC M5.9 HS V05
    Coding: 00000
    Shop #: WSC 00066
    VCID: 132559C761805386391-4A3A
    1 Fault Found:
    17908 - Fuel Pump Relay (J17)
    P1500 - 35-10 - Electrical Malfunction - Intermittent
    Readiness: 1110 1101
    Address 03: ABS Brakes Labels: 3A0-907-379.lbl
    Part No: 3A0 907 379 A
    Component: ABS/EDS ITTAE 20 GI V00
    Coding: 03604
    Shop #: WSC 23126
    VCID: 285F1E2BC806C05EFC3-49D8
    2 Faults Found:
    01276 - ABS Hydraulic Pump (V64)
    16-00 - Signal Outside Specifications
    00287 - ABS Wheel Speed Sensor; Rear Right (G44)
    35-10 - - - Intermittent
    Address 15: Airbags Labels: 6N0-909-60x-VW2.lbl
    Part No: 6N0 909 603 D
    Component: AIRBAG VW2 V00
    Coding: 00068
    Shop #: WSC 00066
    VCID: 3365F94701C0B386591-4A9C
    5 Faults Found:
    00588 - Airbag Igniter; Driver Side (N95)
    32-00 - Resistance Too High
    00589 - Airbag Igniter 1; Passenger Side (N131)
    00532 - Supply Voltage B+
    06-10 - Signal too High - Intermittent
    00595 - Crash Data Stored
    35-00 - -
    07-10 - Signal too Low - Intermittent
    End ---------------------------------------------------------------------
  2. Toyotec
    Fuel pump relay.
    Question is, if the fuel pump relay contacts on 30 and 87 are closed circuited (pump permanently running), will the car fire up?
    Other faults are typical in MK3 cars and would mean when the vehicle does start, your ABS and Airbag lights will stay on.
  3. rudy_nyc1 New Member
    Florida
    Hey Toyotec,
    contacts 30 and 87 need positive and negative to run the pump, yes it will run permanently, I agree. I only did this to test if the circuit is good. To answer your question the car will only crank over but not start. I am not sure why it will not start so I am just testing to see what does not work. Fuse # 18 is dead, the fuse is dead, if powered with my probe (Power Probe4) the pump will run but that does not solve the problems. I suspect that I my need a fuse box so I have ordered a replacement from ebay (used). When this all started The car was fine, it was just being started for 20 mins to charge up the battery, at times I did have to jump it with another car to charge but it did start. Then one day it would only crank but not start. I test for gas on the front rail and I had no gas supply......tested the pump and it was bad so I installed a new pump (ebay). Then I tried to start and it did not, added a half tank of new gas and still no start. I have now begun to test all the ignition part to weed out the culprit........To date I have bought gas pump, cam sensor, ECM and a new ignition switch, I did not buy a crank sensor because it was recently replaced and seems to be working, (I hope). I do a little work on it when I can since it is cold in the garage, this GTI has been in the garage for a few years but it is always in the garage. So I am waiting to get the fuse box and all the replacement fuses since I new have the urge to restore/replace all I can afford to get it back running.......1996 to 2018.......when I get it started I be really happy.
    Injectors have no power, ECM fuse no negative trigger on the relay #3, fuse #18 dead, Fuel pump relay no negative trigger relay #12 and seems to be missing ignition in the fuse box so just waiting to try a replacement fuse box. I AM CONFUSED, WHAT ELSE DOES IT NEED!!!!!
  4. rudy_nyc1 New Member
    Florida
    I received my replacement fuse box in great condition.....original OEM part but sadly it did the same as mine.
    pin (Z1) I think my diagram is the supply for the injectors has no out put, fuse #18 has no power with ignition on, the fuse is good.
    A2Resource
    Central Electric 2
    Central Electric 2 in Volkswagens. Covers 89-99 Golf and Jetta, 90-97 Passat, all Cabrios, Corrados, and EuroVans.
    Central Electric Fusebox rear picture
    A2Resource > Electrical Systems > Fuse Box Information > Central Electric 2
    Fuse Box:
    Connector Outside Fusebox Inside Fusebox Color
    -30 30B, for fuel pump power Main Fusebox Battery Power Red
    -30B 30, for fuel pump power Fuel Pump Relay Input Red
    -Z1 Injector Power (1990+ 8v), Glow Plug Fuse (diesel), inlet manifold pre-heat (carb) Fuel Pump/Glow Plug Relay Output Red/Black or Red/Yellow (gas), Red/White (diesel and carb)
    -Z2 Battery Ground Main Fusebox Ground Brown
    A1 Front Wiring Harness, Left Yellow
    A1/01 Headlight, Left Headlight, Left, Fuse 1 Yellow/Black
    A1/02 Turn Signal Light, Left Front Turn Signal Switch Black/White
    A1/03 - Main Fusebox Ground -
    A1/04 Parking Light, Left Front Parking Lights, Left, Fuse 8 Gray/Black
    A1/05 Radiator Cooling Fan Thermoswitch Battery Power, Fuse 19 Red
    A1/06 High Beam Headlight, Left High Beam Headlight, Left, Fuse 11 White/Black
    A1/07 Horns, Radiator Cooling Fan After-Run Control Unit Main Fusebox Start/Run Power, Fuse 13 Black/Yellow
    A1/08 Horns Horn Relay Output Brown/Black
    A2 Front Wiring Harness, Right Yellow
    A2/01 Alternator (Exciter Wire) (Mk2, others 1990 only) Battery Light Blue
    A2/02 Parking Light, Right Front Parking Lights, Right, Fuse 7 Gray/Red
    A2/03 Headlight, Right Headlight, Right, Fuse 2 Yellow
    A2/04 Turn Signal Light, Right Front Turn Signal Switch Black/Green
    A2/05 Ground for Lights, Right Front Main Fusebox Ground Brown
    A2/06 Alternator (W Terminal, Diesel only) Tachometer Red/Black (diesel only)
    A2/07 High Beam Headlight, Right High Beam Headlight, Right, Fuse 12 White
    A2/08 Fog Lights Fog Light Switch White/Yellow
    B Headlight Washer Wiring Harness Green
    B/01 To B/2 (Washer Pump Power) Headlight Washer Relay Power Green/Red
    B/02 To B/1 Washer Pump Power (front)/Ground (rear) Green/Red
    B/03 To D/4 (Headlight power) or direct to Headlight Switch Headlight Switch Low Beam Power White/Black
    B/04 To C/3 (Ground) or direct to Ground Headlight Washer Relay Brown
    B/05 To Y/2 (Battery Power) Headlight Washer Relay Input Red
    B/06 Headlight Washer Pump Headlight Washer Relay Output Red
    C Engine Wiring Harness, Basic Accessories Yellow
    C/01 Brake Fluid Level Switch Brake Warning Light Blue/Brown
    C/02 Washer Pump Power (front)/Ground (rear) Wiper Switch Washer Pump switch Green/Red
    C/03 From B/4 Main Fusebox Ground Brown
    C/04 Radiator Cooling Fan After-Run Control Unit (Corrado) Main Fusebox Ground Brown
    C/05 Low Coolant Level Sender Main Fusebox Ground Brown
    C/06 Low Coolant Level Sender (1989 only) Low Coolant Level Control Unit Blue/Red (1989 only)
    C/07 Washer Pump Ground (front)/Power (rear) Wiper Switch Washer Pump switch Brown/Blue
    C/08 Low Coolant Level Sender (1990+) Gauge Cluster Blue/Red (1990+)
    D Miscellaneous Equipment Green
    D/01 - Alternator (Exciter Wire) -
    D/02 - Headlight, Left, Fuse 1 -
    D/03 Heated Outside Mirrors (models with "always on" mirrors) Main Fusebox Run Power, Fuse 4 Yellow/Green
    D/04 To B/3 Headlight Switch Low Beam Output White/Black
    D/05 Glove Compartment Light, Power Sunroof Switch Main Fusebox Run Power, Fuse 4 Black/Red
    D/06 - Tachometer -
    D/07 ABS Hydraulic Pump Relay Main Fusebox Run Power Black/Yellow
    D/08 Auto. Trans. Shift Lock Control Module, Interlock Relay, Malfunction Indicator Switch, E/2 (cluster power for A3) Main Fusebox Start/Run Power Black
    D/09 Heated Washer Nozzles, Heated Seats, Power Window Relay Main Fusebox Start/Run Power, Fuse 14 Black
    D/10 Seatbelt Warning Light Seatbelt Warning Light from Relay White/Violet or Green
    D/11 Cruise Control Switch (manual transmission only), Power Mirror Switch, E/2 (Cluster Power, 1991+ Corrado, Passat, all other models) Main Fusebox Start/Run Power, Fuse 14 Black
    D/12 Cigarette Lighter, Auto. Trans. Console Light, Heated Seat Switch Light, Aux. Heater (EuroVan), Power Top Switch (Cabrio) Dash Lights Gray/Blue
    E Instrument Wiring Harness Green
    E/01 - Brake Warning Light -
    E/02 D/11 or D/8 (Start/Run Power for cluster, 1991+ Corrado, Passat, all other models), Immobilizer Module U2/1 Black
    E/03 Brake Light Switch Brake Lights Red/Black
    E/04 Brake Light Switch Main Fusebox Battery Power, Fuse 20 Red/Yellow
    E/05 Fresh Air Control Lever Light, Cassette Storage Light, Ashtray Light, Glove Compartment Light (some models), Radio (some models), Diagnostic Connector (some models) Main Fusebox Ground Brown
    F Engine Compartment/Management, Right Side White
    F/01 Starter, or Starting Interlock Relay, or Clutch Position Switch, or Auto. Trans. Controller Main Fusebox Starter Power Red/Black
    F/02 - G1/1 -
    F/03 Alternator Exciter Wire (all cars 1991+ except Mk2) Battery Light Blue
    F/04 Engine Block, or Fuel Pump After-Run Relay (G60), or Ground for brake pad wear sensors Main Fusebox Ground Brown
    F/05 Digifant ECU Pin 1, Thermotime Switch (CIS-E) Main Fusebox Starter Power Red/Black (CIS-), Brown/Red (1989) or Red/Green (1990+) (Digifant)
    F/06 Back-Up Light Switch, Auto. Trans. PNP Switch Main Fusebox Start/Run Power, Fuse 14 Black/Red
    F/07 Back-Up Light Switch, Auto. Trans. PNP Switch Back-Up Lights Black/Blue
    F/08 Crankcase Ventilation Heating Element (G60) Main Fusebox Ground Brown
    F/09 Auto. Trans. Control Module Tachometer Signal Red/Black
    F/10 - (no pin) -
    G1 Engine Compartment/Management, Right Side White
    G1/01 - F/2 -
    G1/02 Outside Air Temp Sender Ground Gauge Cluster (MFA) Brown/White
    G1/03 ECU- Fuel Pump Relay Turn-On (gas), Engine Temp Sender (Pre-heat, diesel), thermoswitch for preheat (carb) Fuel Pump Relay Power Red/Yellow (gas), Blue/White (diesel)
    G1/04 Ignition Coil Pin 15 (Digifant and CIS-E), Motronic ECU Pin 14 and coil power stage Pin 1(Motronic), Altitude Correction and Fuel Cut-Off Valves (diesel) Main Fusebox Start/Run Power Black (gas), Red/Black and Black/Red (diesel), Violet/White (carb)
    G1/05 Ground on Cylinder Head Ground (for gauges/warning lights) Brown/White
    G1/06 Motronic ECU Pin 34, Vehicle Speed Sensor Main Fusebox Ground Brown/Red
    G1/07 Overrun Cutoff Valve, G60 Difigant ECU Power Overrun Cutoff Relay, ECU Relay Brown/White (Carb only) or Black/White (G60 only)
    G1/08 Heated Oxygen Sensor Power Fuel Pump Relay Output, Fuse 18 Red/White
    G1/09 MIL Lamp from ECU (TDI) Gauge Cluster MIL Light Yellow/White
    G1/10 Digifant/Digijet ECU Power, Injector Power (1989 only), ISV Power (G60 only) Digifant ECU Relay Output Black/Yellow
    G1/11 Vehicle Speed Sensor Gauge Cluster White/Blue
    G1/12 Ignition Coil Pin 1 (all Mk2, most others '90 only), ECU tach signal (all 91+ except Mk2) Tachometer Red/Black (coil) or Green/Black (ECU)
    G2 Engine Compartment/Management, Right Side White
    G2/01 Oil Temperature Sender Gauge Cluster (MFA) Green/Black
    G2/02 Outside Air Temp Sender Gauge Cluster (MFA) White/Red
    G2/03 Coolant Temperature Sending Unit Coolant Gauge Yellow/Red
    G2/04 Knock Control Unit, Oxygen Control Unit, and Throttle Switches (CIS-E), automatic choke and overrun cutoff valve (carb), Heated O2 Sensor (Digijet), Fuel Pump After-Run Control Unit and Crankcase Ventilation Heater (G60) Main Fusebox Start/Run Power, Fuse 15 White (carb), Black (all others)
    G2/05 MIL Light from Motronic ECU (Passat VR6) Glow Plug Relay Pin 9 Yellow/White
    G2/06 - Fuel Pump Relay Pin 5 -
    G2/07 Door Switches (Cabrio A3.5) Fuel Pump Relay Pin 7, T1 Brown/White
    G2/08 Secondary Air Injection Pump Power, EVAP Canister Valve Power (VR6) Fuel Pump Relay Output Red/Blue
    G2/09 VR6/ABA Motronic ECU (Fuel Pump Input) Fuel Pump Relay Input Red
    G2/10 High Oil Pressure Switch Oil Pressure Warning Unit Yellow
    G2/11 Low Oil Pressure Switch Oil Pressure Warning Unit Blue/Black
    G2/12 - (no pin) -
    H1 Steering Column Wiring Harness Red
    H1/01 Ignition Switch Starter Run, or from Starter Interlock Relay Main Fusebox Starter Power Red/Black
    H1/02 Ignition Switch Battery Power Battery Power Red
    H1/03 Ignition Switch Run Power Load Reduction Relay Power Black/Yellow
    H1/04 Ignition Switch Start/Run Power Main Fusebox Start/Run Power Black
    H1/05 Emergency Flasher Switch (Turn Signal power) Main Fusebox Start/Run Power, Fuse 17 Black/Blue
    H1/06 Horn Button, Emergency Flasher Switch, Turn Signal Switch Main Fusebox Ground Brown
    H1/07 Ignition Switch Key-in Power for Seatbelt Relay, Automatic Shoulder Belt Control Module, Radio Seatbelt Warning Relay Pin 5 Brown/Red
    H1/08 Wiper Switch Washer Pump switch Washer Pump Power (front)/Ground (rear) Green/Red
    H1/09 Wiper Switch Washer Pump switch Washer Pump Ground (front)/Power (rear) Green/White
    H1/10 Ignition Switch Power When Off H2/05 Green
    H2 Steering Column Wiring Harness Red
    H2/01 Horn Button Horn Relay Power Brown/Blue
    H2/02 From Parking Light Switch, Right Parking Lights, Right Green/Red
    H2/03 From Parking Light Switch, Left Parking Lights, Left Green/Black
    H2/04 Emergency Flasher Switch, Turn Signal Switch (right output) Turn Signal Lights, Right Black/Green
    H2/05 Power To Parking Light Switch H1/10 Green
    H2/06 Emergency Flasher Switch, Turn Signal Switch (left output) Turn Signal Lights, Left Black/White
    H2/07 - (no pin) -
    H2/08 Emergency Flasher Switch, Turn Signal Switch Input Flasher Relay Output Black/White/Green
    J Steering Column Wiring Harness Red
    J/01 High Beam Headlight Switch, Daytime Running Lights Relay (Golf only) Low Beam Headlight Fuses White
    J/02 High Beam Headlight Switch Headlight Switch Low Beam Output White/Black
    J/03 High Beam Headlight Switch, Daytime Running Lights Resistance (Jetta only), Dim Driving Lights (pin 56D with resistor, UK only) High Beam Headlight Fuses Yellow
    J/04 High Beam Headlight Switch, Emergency Flasher Switch Main Fusebox Battery Power Red/Yellow
    J/05 Wiper Switch Low/Park Output (positive when low/moving, ground when parked/off) Washer/Wiper Relay (low/park input) Green
    J/06 Wiper Switch Intermittent Output Washer/Wiper Relay Brown/Black
    J/07 Wiper Switch Main Fusebox Run Power, Fuse 5 Black/Gray
    J/08 Emergency Flasher Switch (Flasher Relay Power) Flasher Relay Power/Input White/Yellow
    J/09 Wiper Switch Windshield Wiper Motor Park Switch (positive when moving, grounded when parked) Green/Black
    J/10 Wiper Switch High Output Windshield Wiper Motor (High) Green/Yellow
    K Rear Wiring Harness Black
    K/01 Turn Signal, Left Rear Turn Signal Switch (left output) Black/White
    K/02 Parking Light, Right Rear Parking Lights, Right, Fuse 7 Gray/Red
    K/03 Parking Light, Left Rear Parking Lights, Left, Fuse 8 Gray/Black
    K/04 Brake Lights Brake Light Switch Black/Red
    K/05 License Plate Lights Plate Lights, Fuse 3 Gray/Green
    K/06 Rear Window Wiper Park Switch Main Fusebox Run Power, Fuse 4 Black/Yellow
    K/07 Turn Signal, Right Rear Turn Signal Switch (right output) Black/Green
    K/08 Back-Up Lights, Automatic Belt Control Module, Right (Corrado/Passat) Back-Up Light Switch Black
    K/09 Rear Window Wiper Motor Rear Window Wiper Relay Green/Black
    K/10 Rear Fog Light Fog Light Switch Green/White
    K/11 Fuel Gauge Ground (1990-92 A2 only), Rear Spoiler Control Unit Ground (Corrado), Rear Ashtray Light Ground (Passat, A3), Interior Lights (A3), Sunroof (some models), Rear Ashtray Light, Chassis Ground Main Fusebox Ground Brown/Blue (A2), Brown/White (Corrado)
    K/12 Rear Window Defogger, Heated Mirrors (models with switched mirror heating) Rear Window Defogger Switch White
    L Interior Wiring Harness Black
    L/01 Parking Brake Switch, Interior Lights (some models), Diagnostic Connector (some models) Main Fusebox Ground Brown
    L/02 Driver's Door Switch, Seatbelt Switch (models without Automatic Belts) Seatbelt Warning Relay Pin 3/86 (Door Open) Gray/Red, Black/White (Automatic Belts)
    L/03 Automatic Shoulder Belt System B Pillar Switch (Corrado/Passat), or Parking Lights (models with Parking Light Buzzer) Seatbelt Warning Relay Pin 7/GB (Passenger Belt Not Ready), Pin 7/58 (Parking Light Buzzer) Gray/Black
    L/04 Seatbelt Switch, Starter Interlock Relay, Driver Side B Pillar Magnetic Switch (Automatic Belts/Driver Belt Not Buckled) Seatbelt Warning Relay Pin 2/GF Black/Green, Brown/Yellow and/or Brown/Blue, or Gray/Red
    L/05 Luggage Compartment Light Main Fusebox Battery Power, Fuse 21 Red
    L/06 Parking Brake Switch Brake Warning Light Brown/Yellow
    L/07 Interior Lights, Diagnostic Connector, Central Locking, Power Sunroof Motor (1993+) Main Fusebox Battery Power, Fuse 21 Red
    L/08 - (no pin) -
    M Fuel Tank Wiring Harness Black
    M/01 Fuel Pumps Ground Main Fusebox Ground Brown
    M/02 Fuel Pumps Power Fuel Pump Relay Output, Fuse 18 Red/Yellow
    M/03 Fuel Gauge Sending Unit Fuel Gauge Violet/Black
    M/04 Water Separator Sender (diesel) Glow Plug Relay Pin 9, Glow Plug Light Blue/Green
    M/05 Water Separator Power (diesel), Cassette Storage Light (some models), Rear Spoiler Control Unit (Corrado), Power Sunroof Switch (1993+) Main Fusebox Start/Run Power, Fuse 16 Black, Black/Yellow (diesel), Black/Blue (Corrado)
    M/06 Fuel Gauge Sending Unit (1989 A2, All Other Models) Ground (for gauges/warning lights) Brown/Blue
    N Air Conditioning Wiring Harness Green
    N/01 Fresh Air Fan, Climatronic Unit A/C Relay High Speed Fan Output Black
    N/02 Radiator Cooling Fan Low Speed A/C Relay Cooling Fan On" Output Red/White
    N/03 Main Heater Fuse, From Battery A/C Relay Pin 4 Red
    N/04 A/C compressor (via thermostat and pressure switches) A/C Relay Compressor Output Green/Yellow
    N/05 A/C Switch A/C Relay A/C "On" Switch Red/Black
    N/06 Fan Speed 4, Climatronic Unit A/C Relay High Speed Fan Input Yellow/Red
    P Defrost/Fog Light Switch Wiring Harness Blue
    P/01 Fog Light Switch Front Fog Lights Power Front Fog Lights White/Yellow
    P/02 Rear Window Defogger Switch, Heated Mirrors (1989-early 1990 only) Main Fusebox Run Power, Fuse 9 Black/Yellow, Black (1989 only)
    P/03 Rear Window Defogger Switch, Heated Mirrors (1982+ Corrado, Passat) Rear Window Defogger White/Green
    P/04 Fog Light Switch Power Fog Light Relay, Fuse 10 Gray/Yellow
    P/05 Rear Window Defogger Switch Light and Indicator Light Main Fusebox Ground Brown
    P/06 Fog Light Switch Rear Fog Light Power Rear Fog Light Green/White
    P/07 Rear Window Defogger Switch Light Dash Lights Gray/Blue
    P/08 Fog Light Switch Light and Rear Indicator Light Main Fusebox Ground Brown
    P/09 Fog Light Switch Light Dash Lights Gray/Blue
    P/10 - (no pin) -
    Q Dashboard Misc. Wiring Harness Blue
    Q/01 Cigarette Lighter, Ashtray Light, Diagonostic Connector, Luggage Compartment Release Switch, Door Lock/Unlock Switch (A3), AC Switch (some models), Interior Fan (some models), Fresh Air Control Panel Light (some models), Glove Compartment Light (some models) Main Fusebox Ground Brown
    Q/02 Fresh Air Fan/AC Switch or Climatronic Unit Main Fusebox Run Power, Fuse 6 Black/Red
    Q/03 Cigarette Lighter, Radio, Amplified Speaker Power Main Fusebox Battery Power, Fuse 22 Red/Gray
    Q/04 Cassette Storage Light (some models), Glove Compartment Light (some models), Climatronic Unit, Voltmeter and Oil Pressure Gauge (Corrado) Main Fusebox Start/Run Power, Fuse 16 Black/Yellow
    Q/05 Power Antenna Power Main Fusebox Battery Power, Fuse 21 Red
    Q/06 Radio, Cigarette Lighter/Ashtray Light, Climate Control Unit, Cassette Storage Light (some models), Accessory Gauges (Corrado) Dash Lights Gray/Blue
    R Light Switch Wiring Harness Blue
    R/01 Fog Light Switch Rear Fog Light Power U1/13 Gray/White
    R/02 Headlight Switch Parking Lights (Left) Output Parking Light Fuse (Left) Gray/Black
    R/03 Headlight Switch Dash Light Dimmer Input Dash Lights, Fuse 3 Gray
    R/04 Headlight Switch Dash Light Dimmer Output Dash Lights Gray/Blue
    R/05 Headlight Switch Parking Lights Power Main Fusebox Battery Power Red
    R/06 Headlight Switch Parking Lights (Right) Output Parking Light Fuse (Right) Gray/Red
    R/07 Headlight Switch Parking Lights Output Dash Light Dimmer/Plate Light Fuse Gray/Green
    R/08 Headlight Switch (Light), Defroster Switch (models with combined head/fog light switch) Main Fusebox Ground Brown
    R/09 Headlight Switch Low Beam Output Headlight Fuses White/Black
    R/10 Headlight Switch Run Power Load Reduction Relay Power Black/Yellow
    S Wiper Motor Wiring Harness White
    S/01 Windshield Wiper Motor Power To Park Switch Main Fusebox Run Power, Fuse 5 Black/Gray
    S/02 Windshield Wiper Motor Washer/Wiper Relay (high output) Green
    S/03 Windshield Wiper Motor Main Fusebox Ground Brown
    S/04 Windshield Wiper Motor Park Switch (positive when moving, ground when parked) Wiper Switch Green/Black
    S/05 Windshield Wiper Motor (High) Wiper Switch High Output Green/Yellow
    T Engine Management, Europe Wiring Harness Green
    T1 - Fuel Pump Relay Pin 7 -
    T2 - Tachometer -
    U1 Instrument Cluster Wiring Harness Blue
    U1/01 Gauge Cluster (MFA) Oil Temperature Sender Black/White
    U1/02 Gauge Cluster (MFA) Outside Air Temp Sender Violet
    U1/03 Gauge Cluster (Oil Pressure Warning Unit) High Oil Pressure Switch Yellow
    U1/04 Gauge Cluster (warning lights/gauges) (1990 Corrado and Passat, all A2) Main Fusebox Start/Run Power, Fuse 16 Black
    U1/05 Gauge Cluster (Oil Pressure Warning Unit) Low Oil Pressure Switch Red/White
    U1/06 Gauge Cluster Tachometer Ignition Coil Pin 1 Green
    U1/07 Gauge Cluster (MFA) Outside Air Temp Sender Ground Blue/White
    U1/08 Gauge Cluster Glow Plug Light (diesel only), MIL Light (Passat VR6) Glow Plug Relay Pin 9 Green/White (diesel), Yellow/White
    U1/09 Gauge Cluster MIL Lamp (TDI) TDI/Motronic ECU White
    U1/10 Gauge Cluster (main ground) Main Fusebox Ground Brown
    U1/11 Gauge Cluster Speedometer Vehicle Speed Sensor White
    U1/12 Gauge Cluster Fuel Gauge Fuel Gauge Sending Unit Blue
    U1/13 Gauge Cluster Rear Fog Light Indicator (Transporter- Europe) Rear Fog Light Switch (R/1) White
    U1/14 Gauge Cluster Dash Lights Gray
    U2 Instrument Cluster Wiring Harness Blue
    U2/01 Gauge Cluster (lights/gauges) (1991+ Corrado, Passat, all other models) E/2 Black
    U2/02 Gauge Cluster Speed Sensor Violet
    U2/03 Gauge Cluster (Corrado/A3) Seatbelt Warning Light from Relay Yellow
    U2/04 Gauge Cluster (MFA) MFA Switch (Mode) Black
    U2/05 Gauge Cluster (1990+) Low Coolant Level Sender Violet (1990+)
    U2/06 Gauge Cluster Turn signal light Flasher Relay Output Green
    U2/07 Gauge Cluster High Beam Light High Beam Headlight, Left, Fuse 11 Blue/White
    U2/08 Gauge Cluster (MFA) MFA Switch (Memory 1/2) Green/White
    U2/09 Gauge Cluster Coolant Gauge Coolant Temperature Sending Unit Yellow/Red
    U2/10 Gauge Cluster Brake Warning Light (A3) Brake Warning Light Brown
    U2/11 Gauge Cluster (clock and MFA) Main Fusebox Battery Power, Fuse 21 Red
    U2/12 Gauge Cluster Battery Light Alternator (Exciter Wire) Blue
    U2/13 Gauge Cluster (Ground for gauges/MFA) Ground (for gauges/warning lights) Brown/White
    U2/14 Gauge Cluster (MFA) MFA Switch (Reset) Gray
    V MFA Switch Wiring Harness Green
    V/01 MFA Switch (Memory ) Gauge Cluster (MFA) Red/White
    V/02 MFA Switch (Ground) Ground (for gauges/warning lights) Brown/White
    V/03 MFA Switch (Mode) Gauge Cluster (MFA) Blue/Yellow
    V/04 MFA Switch (Reset) Gauge Cluster (MFA) Yellow/Red
    W ABS Wiring Harness Green
    W/01 Motronic ECU Pin 2, Cruise Control Unit, Rear Spoiler Control Unit, Radio, Climatronic Unit, Radio Buzzer Speed Sensor White/Yellow
    W/02 ABS Control Unit, Diagnostic Connector ABS Warning Light Gray/Black
    W/03 - Main Fusebox Run Power -
    W/04 ABS Control Unit, Auto. Trans. Shift Lock Control Module, Cruise Control Unit Brake Lights Black/Red
    W/05 ABS Pressure Switches Warning Lights Brown/White
    W/06 ABS Brake Fluid Level Switch and Control Unit Warning Lights White/Blue
    X Extra Warning Lights Wiring Harness Green
    X/01 Warning Lights Main Fusebox Starter Power Red/Black
    X/02 Ground for warning lights Main Fusebox Ground Brown
    X/03 Brake Warning Light, ABS light (A3), Power Top Module (Cabrio) Brake Warning Light Gray or White/Red (A3)
    X/04 Start/Run Power for warning lights, Power Top Module (Cabrio) Main Fusebox Start/Run Power, Fuse 16 Black
    X/05 ABS Warning Lights ABS Brake Fluid Level Switch and Control Unit White/Blue
    X/06 Trailer Towing Light Flasher Relay -
    X/07 ABS Warning Lights ABS Pressure Switches Brown/White
    X/08 ABS Warning Light ABS Control Unit, Diagnostic Connector Yellow/Red
    Y Individual Circuits, Battery Power Red
    Y/01 Power Seat Fuse, Automatic Shoulder Belt Control Module Main Fusebox Battery Power Red
    Y/02 Starting Interlock Relay, Power Window Fuse Main Fusebox Battery Power Red
    Y/03 Battery Positive Main Fusebox Battery Power Red
    Y/04 Motronic ECU Pin 19, Fuel Pump After-Run Control Unit (G60) Main Fusebox Battery Power Red
    Relays:
    Num. Relay Arrangement and Pinout (with control number stamped on relay)
    1 A/C Relay (13 or 140)
    1 A/C Switch
    3 Fan Switch High Speed
    4 Battery, Fuse 23
    5 A/C Clutch (via pressure and temperature switches)
    6 Main Fusebox Battery Power, Fuse 19
    7 Main Fusebox Ground
    8 Fresh Air Fan
    2 Rear Wiper Relay (72)
    1 Main Fusebox Ground
    2 Main Fusebox Run Power, Fuse 4
    3 Rear Wiper Motor
    4 Wipe/Wash Signal from Switch
    3 Digifant Control Unit (30 or 32), Motronic OBD1 Control Unit (109)
    2 Tachometer
    3 Main Fusebox Start/Run Power
    4 Main Fusebox Battery Power
    5 To ECU (relay turn-on) (1990 G60, ABA/VR6 OBD1 only)
    6 To ECU and Engine Electronics
    4 Load Reduction Relay (18)
    1 From Ignition Switch Run Power
    2 To Main Fuse Box Run Power
    3 Main Fusebox Battery Power
    5 Low Coolant Level Control Unit (43)
    1 Main Fusebox Start/Run Power
    2 Low Coolant Level Sensor
    3 Coolant Temperature Sensor, Gauge
    6 Flashers (21)
    2 Flasher Output
    3 Flasher Input/Power
    4 X/6 (Trailer Light)
    7 Headlight Washer (33)
    1 Main Fusebox Ground (B/4 to C/3 to Ground)
    2 Headlight Washer Pump
    3 Headlight Switch Pin 56 (headlights) (B3 to D4 to light power)
    4 Main Fusebox Battery Power (B/5 to Y/2)
    5 Windshield Washer Pump (B/1 to B/2 to washer pump power)
    8 Wash/Wipe/Intermittent Relay (19 for standard relay, 99 for variable intermittent module)
    2 Intermittent Switch
    3 Main Fusebox Run Power, Fuse 5
    4 Park/Low Signal (ground when parked, positive when on low speed)
    5 Wiper Motor Low Speed Output
    6 Wash Switch (positive for front wash)
    9 Seat Belt Warning Control Unit (4 or 29)
    2 Seat Belt Switch
    3 Door Switch
    4 Seatbelt Light
    5 "Key In" Power from Ignition Switch
    6 Main Fusebox Start/Run Power
    7 Automatic Shoulder Belt Controller
    9 Radio/Lights Buzzer (36)
    1 Main Fusebox Ground (not used)
    2 A1/4 (Left Parking Lights)
    3 Vehicle Speed Sensor
    4 Seatbelt Light (not used)
    6 Main Fusebox Start/Run Power (not used)
    7 A2/2 (Right Parking Lights)
    10 Fog Light Relay (110 for fog lights with low beam headlights only, 53 for parking light/high beam fog lights)
    1 Parking Light Power
    2 Headlight Switch Headlight Power (Low/High)
    3 Fog Light Switch Power, Fuse 10
    5 Main Fusebox Ground
    6 Low Beam Headlight Power
    11 Horn (53)
    2 To Horns
    3 Main Fusebox Ground
    4 From Horn Button
    12 Fuel Pump Relay (80, 67 or 167)
    1 Main Fusebox Starter Power (not used)
    2 Main Fusebox Start/Run Power
    3 To ECU (Fuel Pump Turn-On)
    4 To Fuse 18, Fuel Pump, Oxygen Sensor Heater
    5 G2/6 (not used)
    6 Main Fusebox Battery Power From 30B
    7 G2/7, T1 (not used)
    8 Main Fusebox Ground (not used)
    9 M/4, U1/8, G2/5 (not used)
    12 Glow Plug Relay (102 or 104)
    3 Engine Temp Sender (preheat)
    4 Glow Plugs (Z1)To Fuse 18 (not used)
    5 G2/6 (not used)
    9 Water Separator, Glow Plug Light
    Fuses:
    Num. Standard Fuse Arrangement Power Rating
    1 Low Beam Headlight, Left Dimmer/Flasher Switch pin 56b (Low Beam Headlights) 10A
    2 Low Beam Headlight, Right Dimmer/Flasher Switch pin 56b (Low Beam Headlights) 10A
    3 License Plate, Dash Lights Headlight pin 58 (Park. Lights) 10A
    4 Rear Window Wiper, Glove Compartment Light (some models) Main Fusebox Run Power 15A
    5 Windshield wiper/washer system Main Fusebox Run Power 15A
    6 Fresh Air Fan, A/C Main Fusebox Start/Run Power 20A
    7 Right Parking Lights Headlight pin 58R (Park. Lights) 10A
    8 Left Parking Lights Headlight pin 58L (Park. Lights) 10A
    9 Rear window defogger Main Fusebox Run Power 20A
    10 Fog lights Fog Light Relay Output 15A
    11 High Beam headlight, Left Dimmer/Flasher Switch pin 56a (High Beam Headlights) 10A
    12 High Beam Headlight, Right Dimmer/Flasher Switch pin 56a (High Beam Headlights) 10A
    13 Horns Main Fusebox Start/Run Power 10A
    14 Back-Up Lights Main Fusebox Start/Run Power 10A
    15 Knock Control Unit, Oxygen Control Unit, and Throttle Switches (CIS-E), automatic choke and overrun cutoff valve (carb), Heated O2 Sensor (Digijet), Fuel Pump After-Run Control Unit and Crankcase Ventilation Heater (G60) Main Fusebox Start/Run Power 10A
    16 Warning Lights, Voltmeter and Oil Pressure Gauges and Rear Spoiler Power (Corrado) Main Fusebox Start/Run Power 10A
    17 Turn Signals Main Fusebox Start/Run Power 10A
    18 Fuel Pump, Heated O2 Sensor Fuel Pump Relay Output 20A
    19 A/C Relay, Radiator Cooling Fan After-Run Main Fusebox Battery Power 30A
    20 Brake lights Main Fusebox Battery Power 10A
    21 Luggage Compartment Light, Diagnostic Connector, Interior Light, Instrument Cluster (MFA and Clock memory) Main Fusebox Battery Power 15A
    22 Radio, Diagnostic Connector Main Fusebox Battery Power 10A
  5. rudy_nyc1 New Member
    Florida
    Z/1 is fed from the fuel relay as is fuse 18 so if its not being triggered by the ecu then neither will get power, for testing purposes as Toyotec said you can loop the 2 terminals on the fusebox with a bit of wire for the 30 and 87 to bypass the relay, or another thing you can do is swap the 18 relay into slot 12. You could also use an earlier 17 relay or mk4 era 100 relay, this way fuel pump, G1/8, G2/8 and Z/1 will be live all the time ignition is on.
    if it still doesn't fire jumped like this and all the pump relay power points mentioned above are live when jumped as well you can rule out the fuel relay and fusebox fuel pump section at least, looking at my US diagrams it looks like your ECU has an ignition trigger from G2/4 which is fed by fuse 15 so thats worth a check. As its an OBD2 ECU you dont need the 109 relay in slot 3 either so you can get rid of that one.
    since you have vagcom plug it back in and go into the ECU measuring blocks, find the engine rpm block and see fi it goes up while cranking over, if it doesnt then your crank sensor is bad or the wiring to it
    edit: actually since you can scan it with vagcom the ignition trigger must be ok at least, so you can skip that check...
  7. Toyotec
    In a fairly modern car as a MK3, it is unlikely to have a fuse box issue or have concerns with the electrics, unless it has been previously tampered with and left in a mess.
    That has been my experience with working on vehicles over a few decades.
    Having owned a EU/UK Spec MK3 Golf VR6, I can say I never had an electrical problem like that what so ever.
    It is likely as the fuel pump relay (J17) is not working or giving any output from KL87, you are unlikely to have the MAF, Lambda sensor heater, purge solenoid (not shown) , fuel pump and injectors working.
    That is a lot of systems to suddenly go down.
    This does suggest the ECU driver for the f/p relay is not being pulled low for some logical reason.
    I have found it is usually some error that causes problems like these, so I have to ask what was the history of the vehicle leading up to this problem?
    I have included the current flow diagrams from the ABV/AAA EU2 VR6 12v engines with a M3.8.1 controller - 021906256. This is very similar to the post 95 controllers M5.9 021906259 parts you have in the North American market.
  8. rudy_nyc1 New Member
    Florida
    Hey toyotec, I also appreciate you feedback on this issue.....thank you for the diagrams.
    I think I bought it in 99, It was a repairable that I had a shop fix it up for me in NY, all was good, drove it with no problems for over 13 yrs then I parked it since I had another car for a few years then it wold not start. tested it and the gas in the tank messed up the pump, so replaced it (pump) and all was good but still was not driving it just stating it up once or twice a month. So the batter was completely dead so I had to jump it.......(did it a few times and no problem), ten the last time I would not start so I tracked it down to be the pump so I replaced it thinking It would just start but it did not and that is were we are at now. So I have replaced and confirmed working quiet a few parts........It has always been a good car so I am not sure why the fuel pump keep messing up I suspect ebay aftermarket cheap pumps ($50) an original is about $200......and yes the old gas did thicken and mess up the original so I drained and thoroughly cleaned the tank and put in fresh new gas. You can also read my reply above to robjonny to get some more history and my next approach on trying to solve the issue. I am looking for better detailed wiring diagrams and I am also a tutorial on VCDS to help me with this problem...... I will keep you updated in a few when I clean some connectors, ground points, and test some connections.
  9. rudy_nyc1 New Member
    Florida
    Hey robjonny, thank you for replying to my post, yes the VR6 is still down and on life support and I need all the help I can get to resuscitate my baby. Anyway, Just waiting to go in the garage to apply your suggestions but it is a bit cold here in Florida......will do very soon, I do have a few things to do in there, clean up all the connectors with a toothbrush and electrical contact cleaner and all the ground points under the battery, I also have tho clean up all the plugs. I all fails the I will be looking to get that Crank Position Sensor, so I will follow your instructions and keep you informed on my situation.......Is It possible you could tell me how to use VCDS to track the problem? Thank you again, I will update you soon robjonny. Thank you again.
  10. rubjonny
    Sure no problem, once you open the software click the top left button for Select control module, then click 01-Engine. once you're logged into the ECU you can click into Fault codes 02 to display just the codes on the ECU, below it is the Meas. Blocks 08 which I mentioned. once in there you can click through to see all your ecu sensor inputs in real time, which is very useful. Engine speed or RPM is the one which tells you what signal if any the ECU is getting from the crank sensor :)
  11. rudy_nyc1 New Member
    Florida
    Update, I have now replaced cam, coil pack (I had an extra one), fuse panel, all new fuses (all of them, including those under the hood), un-pluged and cleaned (with electrical contact cleaner) most of the plugs under the hood. I removed the battery and plate below to get to the ground posts, wire brushed them and cleaned the area with the electrical contact cleaner, ECM (my ECM) and connector as well. Battery has a full charge 12.7v, removed all spark plugs and cleaned them and put them back in the engine, torqued them down to specs 18 ft lbs as my manual said.
    Tried to start it up but it failed, cranked as normal but no start. All the normal dash lights were present. I have gas at the top fuel rail, I have spark, and I see the tach level moving in the dash. i tried about 4 time, I think I heard a sputter but it only happened once. That was it for me for the day, I will be on it again tomorrow with my test probe to verify some signals......I have another ignition switch I will install just to eliminate that possibility (since I have it, new).........but yea, the fuel rail seemed good, it had pressure and gas was present. I will also scan the engine again with VCDS.
  12. rubjonny
    sounds like we're going in the right direction, I take it fuel pump is now running while the engine is cranking over and you have power at Z/1, g1/8 etc?
    was the fuel filter ever done, if the fuel inside the tank went bad the stuff in the lines/rail probably isnt much better. worth pulling the fuel rail out and drop each injector into an equally sized container, crank it and see if you get fuel. friend of mine did a 24v swap and found all 6 injectors were bad, if nothing its probably worth pulling the rail off completly and strip injectors off for a good clean. point the feed pipe into a bucket and crank it to blow out any old fuel left in the lines and work from there
  13. rudy_nyc1 New Member
    Florida
    I am still looking for answers on my GTI, my mechanic friend in NY told me to do a compression test on it but I don't have the tool......he did say I could put a cap of tranny oil in each cylinder to test so that is one road to explore. The other one is based on a video I watched that does hold a great deal of validity due to the age and miles on my GTI.........(slipped Timing chain).......I have never done that job on it, compression....possible, I just have to get a tool. I want to get a cheap usb scope to take a better look. I am a bit shocked that, (1) I started it a few weeks prior to all this, (2) it sounds the same as usual on cranking....... (3) I an not sure on the crank sensor, the most likely to cause this problem!!!!!! I do have tach movement on cranking and I did use a ohm meter to test the CPS. I will up date this feed when I do some more test.....Thank you again rubjonny.......what do you think?
  14. Dox! Forum Member
    Pull a spark plug after cranking, is it wet with fuel?
    Spark
    Fuel
    Compression
    Timing
    If you have all the above the engine should run, what's missing?
  15. rudy_nyc1 New Member
    Florida
    Hey Dax!, the plugs seem fine....I agree that the engine should start with all that. It never really had a problem, it has always been parked in the garage and only started to charge the batt, then tried to start it up one day and it only cranked, normal crank. Read through all my posts to get my story/history on this history.....I am not giving up on it....waiting to get a usb scope to see if that will give me some direction......I need to test compression and some way to look if the timing chain jumped. I will update as soon as I get some more test tools.
  16. shane d Forum Member
    Ireland
    Worth trying to start it on easy start?
  17. rudy_nyc1 New Member
    Florida
    Hey rubjonny, I am still on this project, my cousin in NY told me to try removing all the plugs, unplug the coil, unplug the fuel relay and remove the up stream O2 sensor. So I did all that to blow all the excessive gas out the system and to free up the cat conveter, I also made a short video and this is the link, https://youtu.be/yjLeoVybkCQ. I have another video to post to show when I put them all back in, showing I am getting spark but did not start........He did tell me to get a can of starting fluid for my next test. I have a new scan report below........I am really thinking this needs A FUEL PUMP RELAY SO I WILL ORDER ONE ASAP OEM. PS: since I got spark does that mean my Crank Position Sensor is good?
    Sunday,07,January,2018,20:02:34:62939
    VCDS -- Windows Based VAG/VAS Emulator
    Coding: 00000
    Shop #: WSC 00066
    1 Fault Found:
    Coding: 03604
    Shop #: WSC 23126
    2 Faults Found:
    Coding: 00068
    Shop #: WSC 00066
    5 Faults Found:
    35-00 - -
    Wednesday,17,January,2018,19:29:36:62939
    Coding: 00000
    Shop #: WSC 00066
    No fault code found.
    Coding: 03604
    Shop #: WSC 23126
    2 Faults Found:
    Coding: 00068
    Shop #: WSC 00066
    5 Faults Found:
    35-00 - -
    Address 01: DTCs clearedFriday,26,January,2018,14:52:45:62939
    Coding: 00000
    Shop #: WSC 00066
    Coding: 03604
    Shop #: WSC 23126
    2 Faults Found:
    Coding: 00068
    Shop #: WSC 00066
    5 Faults Found:
    35-00 - -
    OBD DTCs erasedWednesday,31,January,2018,11:53:35:62939
    Coding: 00000
    Shop #: WSC 00066
    VCID: 132559C761805386391-4A9C
    Coding: 03604
    Shop #: WSC 23126
    VCID: 285F1E2BC806C05EFC3-4978
    2 Faults Found:
    Coding: 00068
    Shop #: WSC 00066
    5 Faults Found:
    35-00 - -
    Readiness Status: 0110 1101
    Exhaust Gas Recirculation: Passed
    Oxygen Sensor Heating: Failed or Incomplete
    Oxygen Sensor(s): Failed or Incomplete
    Air Conditioning: Passed
    Seconday Air Injection: Failed or Incomplete
    Evaporative Emissions: Failed or Incomplete
    Catalyst Heating: Passed
    Catalytic Converter(s): Failed or Incomplete
    Tuesday,06,February,2018,11:01:47:62939
    Coding: 00000
    Shop #: WSC 00066
    Readiness: 0110 1101
    Coding: 03604
    Shop #: WSC 23126
    2 Faults Found:
    35-00 - -
    Coding: 00068
    Shop #: WSC 00066
    5 Faults Found:
    35-00 - -
    Address 03: DTCs cleared
    Address 15: DTCs cleared
    Coding: 00000
    Shop #: WSC 00066
    9 Faults Found:
    17633 - Fuel Injector for Cylinder 1 (N30)
    P1225 - 35-10 - Short to Ground - Intermittent
    17634 - Fuel Injector for Cylinder 2 (N31)
    P1226 - 35-10 - Short to Ground - Intermittent
    17635 - Fuel Injector for Cylinder 3 (N32)
    P1227 - 35-10 - Short to Ground - Intermittent
    17636 - Fuel Injector for Cylinder 4 (N33)
    P1228 - 35-10 - Short to Ground - Intermittent
    17833 - EVAP Purge Valve (N80)
    P1425 - 35-10 - Short to Ground - Intermittent
    17859 - Secondary Air Injection System
    P1451 - 35-10 - Short to Ground - Intermittent
    17637 - Fuel Injector for Cylinder 5 (N83)
    P1229 - 35-10 - Short to Ground - Intermittent
    17829 - Secondary Air Injection Solenoid Valve (N112)
    P1421 - 35-10 - Short to Ground - Intermittent
    17638 - Fuel Injector for Cylinder 6 (N84)
    P1230 - 35-10 - Short to Ground - Intermittent
    Coding: 03604
    Shop #: WSC 23126
    2 Faults Found:
    Coding: 00068
    Shop #: WSC 00066
    5 Faults Found
    35-00 - -
  18. rubjonny
    ok let us know how you get on. if you suspect the fuel relay either bridge the socket as eddie said earlier or swap the 18 relay into slot 12. if the car still wont start like this then its not the fuel relay
  19. rudy_nyc1 New Member
    Florida
  20. rudy_nyc1 New Member
    Florida
