Quaife LSD in O2J help
Discussion in 'Transmission' started by RichG60, Jan 21, 2024.
  1. RichG60 New Member
    Devon
    I'm just about to reassemble the gearbox after fitting new bearings and an LSD.
    I have 2 questions.
    First should I be using an assembly grease on the new bearings? There is nothing mentioned in the technical manual.
    My second question is the differential bearing preload. I have a turning torque of just under 20 inch lb's. I understand on the 02a's they used a turning torque between 11-29 in lbs but nothing is listed for the 02J. Is the figure I have reasonable? Any help would be much appreciated :)
    https://youtube.com/shorts/76xZYMuIR6Y
    Thanks
    Rich
  2. GVK
    Not sure if Martin uses the forum these days @Hotgolf he'd be best person to ask.
    RichG60 likes this.
  3. Jon Olds Forum Junkie
    I'm no expert on gearboxes, just build them for my own use. No assembly lube, its flooded in oil and the 02A/J
    are fundamentally the same box, so preload (I would imagine) is the same
    Jon
  4. RichG60 New Member
    Devon
    Thank you for the responses :)
