R36 Turbo mk1
Discussion in 'The Video Forum' started by GVK, Dec 15, 2008.
  1. Toyotec
    That car is lethal dude!
  2. GVK
    Damn right!
  3. PhatVR6 Forum Junkie
    I love the way the fuel rail has 3 inlets, so there's no chance of any cylinder running lean
  4. Rigs Paid Member Paid Member
    Such naughtiness... love it!
  5. davecr32 Forum Member
    It looks like they've cut away the front bulkhead for the centre driveshaft to fit above the standard mk1 steering rack.
    Boxed the tunnel in at the front. then probably ran it inside the original tunnel to the back of the car.
    they've had to mount the gear shifter inside the car to clear up the tunnel for the shaft.
    Also if you look at the lower arms. it looks like they've had to raise the height of the inside pivot points on the lower arms because of the height that the centre shaft has been fitted. They might just be beefed up, its hard to tell.
    Doesn't look like theyve fitted a subframe from a later car.
    That is a superb! I love the way it takes off! :thumbup:
  6. nutter4x4 Paid Member Paid Member
    Lao Peoples Dem. Rep.
    but its only 650ps
  7. GVK
    only.
  8. nutter4x4 Paid Member Paid Member
    well expect a bit more from a gt45rs
    i need one on my peanut :thumbup:
  9. GVK
    Peanut BOOST
