Rear axle, back plate to back plate dimensions
Discussion in 'Chassis' started by A.N. Other, Aug 16, 2007.
  1. rubjonny
    how wide is that axle?
  2. turbotommy Forum Member
    Newcastle upon tyne
    Its 1376mm jonny,its stripped down now so i'll double check.
  3. rubjonny
    earlier wider one then! be interesting to find out what the narrower 4 stud beam uses
  4. A.N. Other Banned after significant club disruption Dec 5th 2
    Passat 1Z TDI 4-stud with drums, '95 model - 1344mm
    - the car I expected to be wider, isn't [:s]
    Managed to measure this from underneath with no probs, so should be an easy measurement for anyone else.
  6. turbotommy Forum Member
    Newcastle upon tyne
    Interesting that is the same width as the 1Z engine toledo,is the front wide track or not? (toledo is not)
    Also measured 2 x 5 stud mk3 golf GTI axles, 1 with ABS & 1 without, both came in at 1358mm.
  7. A.N. Other Banned after significant club disruption Dec 5th 2
    Before I lose this pic again, 1990 spec Mk2 axle with outer strentheners on the trailing section from here
  8. gigaz Forum Member
    my mk2 axle is like that, but has the internal arb, reference checks out as golf mk2 gti G60 or Corrado G60 (same axle)
    1340mm I'm afraid :(
  9. moryan New Member
    Hi, new to this forum, was directed to this thread by members of Ed38 and Autostadt.ie. I have a '94 CL. Can someone tell me it's exact length and what's the narrowest mk2 beam I can fit in it's place?
  10. rubjonny
    94 is right on the changeover for the mk3, see the picture at the top of this page. best bet is measure your beam as it could be the same as mk2 or wider! to measure you'll have to jack the rear up (chock front wheels!) then drop the axle off both the rear shocks so you can get a tape measure across
  11. 1.8tguy New Member
    Has anyone posted the dims for the Mk1 beam? I've been searching but can't find anything maybe I'm missing it, idk.
    I can measure mine tomorrow but I'm not sure if it's actually straight or not.
  12. 1.8tguy New Member
    Ok, I measured the beam on my Mk1 and it's about 129.6cm. Is this ok, is this bent , I don't know , anyone?
    The table is being fixed in post 1.
    From one of my notes offline, that's a straight axle :thumbup:
  14. mat-mk3
    mat-mk3 Administrator Admin
    Bristol
    Table fixed:)
  15. 1.8tguy New Member
    Thank you.
    I'm amazed it's still straight after 35 years :)
  16. rubjonny
    all i could findf in elsawin is check the beam gussets, if kinked then replace beam :)
  17. Maks-g60 New Member
    FB886FDC-34E2-43E6-8298-9EE2C174411D.jpeg Measured a Corrado g60 J reg, 4x100 1344
  18. davidut5 Forum Member
    Romania
    Passat b4 tdi 1996 1341mm disc brake. Axle stub has 6 bolts.
