Rear brake load sensor thingy
Discussion in 'Mk2' started by John A, Apr 3, 2024.
  1. John A Forum Member
    So the old girl went in for an MOT today and she failed. On 2 things
    Reave load sensor not working
    CV gaiter inner nearside not bad I though!
    My question is regarding the brake compensator
    I've read all the links to it, I have a lowered car so have adjusted the spring to take the slack off, it was a little stiff with the spring off so WD40 and nice and free. But how should the lever sit.. it's closed under cars own weight and in centre pin all way in. So any excess weight should pull the pin out to let more fluid through? Is this correct?. I wasn't sure what they checked for? And I could move it against the spring pressure to open it, I'm aware I could be talking in reverse for what it actually does. I mean the cars standing weight and the spring is tighten just so the slacks taken off. PXL_20240403_190801269.jpg PXL_20240403_190747198.jpg PXL_20240403_190725263.jpg
  2. Digi Forum Member
    Is that spring broken?
  3. John A Forum Member
    No definitely not just the way the camera is. Is all one piece.
    Bentley doesn't say much unfortunately
  5. Cressa Paid Member Paid Member
    Fron a Vortex thread
    the above isnt right, the 'factory setting' involves hooking up pressure gauges inline with the rear brakes, then fine tuning them to a specific pressure.
    but in the real world, you do in fact just do as above. set it with the slack taken out of the spring then forget :lol:
  7. PhilRyder
    I would be inclined to remove the whole lot, de rust it and maybe replace the valve body depending on what it looks like inside the connection holes.
