Recommendations for new top mounts
Discussion in 'Chassis' started by Gazzmondo, Mar 6, 2024.
  1. Gazzmondo
    Gazzmondo Paid Member Paid Member
    Gateshead
    Any recommendations for new top mounts for my MK2?
    It's currently got coilovers on, which I'm going to replace with these Eibach lowering springs and Bilstein gas shocks off eBay (£370). Thought it would be a good idea to renew the top mounts at the same time.
  3. Gazzmondo
    Gateshead
  4. PhilRyder
    Gaza, this is the kit we fitted to our MK2. Unfortunately the rear springs are weak and any weight in the rear caused the tyres to rub quite badly.
    Gazzmondo likes this.
  5. RichardDarrenB Paid Member Paid Member
    Christ, that kit was 270 when I bought it for my mk2 about 18 months ago.
    G60 top mounts are less fuss to fit IMO and just as good as MK3 - I've had both
    bri likes this.
  6. RichardDarrenB Paid Member Paid Member
    Was that found to be a fault?
    Same kit on mine 5 up (and 2 tubby dogs in the boot) over 15" BBS RZs and no contact.
  7. PhilRyder
    No idea, just swapped them for Corrado VR6 springs, much better.
    RichardDarrenB likes this.
  8. Tristan
    Do they use the mk2 GTI type bearing?
  9. RichardDarrenB Paid Member Paid Member
    Think it's a stronger version, but yes.
  10. Tristan
    OK. The mk3 one is far superior to mk2, but if g60 is also better that's good.
  11. Gazzmondo
    Gateshead
    So I bought the new mk3 top mounts.
    Springs and shocks next!
  12. Tristan
    Did you get the top spring plate?
  13. KeithMac Forum Junkie
    Kazakhstan
    When I had my MK2 in bits last year the Bonrath Poly top mounts were still in excellent condition, must be nigh on 20 years old now?.
    GVK and Gazzmondo like this.
  14. Gazzmondo
    Gateshead
    Yes. Just waiting for them to be delivered.
  15. Gazzmondo
    Gateshead
    Spring plates have arrived.
  16. Gazzmondo
    Gateshead
    Quick question:
    What about the rear?
  17. Tristan
    Stock is more than good enough.
  18. Gazzmondo
    Gateshead
    I've ordered the 16v kit, as opposed to the 8v one.
    Apparently, the 16v kit has a higher spring rating for the heavier engine.
  19. Gazzmondo
    Gateshead
    So started putting the struts and springs together and the little metal tab on the underside of the plate snapped off. Does this matter? Wasn't very sturdy to start with.
  20. PhilRyder
    I think it’s just a locating tab to make sure the plate is in the correct position against the spring when installing.
