Removing inlet manifold heater
Discussion in 'Carburettor' started by Mk2 driver 1800, Feb 25, 2021.
  1. Mk2 driver 1800 New Member
    Hi everyone only just found out that the hedgehog unboats from the manifold has anyone tried removing it and cutting the spikes of to improve flow I would also smooth out the insides would this be a worthwhile mod or will it just make it run like poo I have a 1.8 driver with a weber 32 34 dmtl carb.
    Won't really make any difference without other changes.
  3. rubjonny
    is a common mod, but doesnt really make any real difference, better off doing the usual gti cam, kjet dizzy, gti 8v manifold and downpipe. these will give proper results
  4. Mk2 driver 1800 New Member
    Thanks for the replies think I'll leave it then for now.
    Tristan likes this.
  5. Tristan
    What does the kjet dizzy do RJ? Better advance?
    yeah just has better ignition map in it, that plus cam main difference between a gti and a 1.8 carb. the gti head flows a bit better too but nothing spectacular
