Royal Blue MK2 GTI, 16v KR then ABF, now abf management+widetrack
Discussion in 'Members Gallery' started by rubjonny, Feb 25, 2006.
  1. Mike_H Forum Addict
    Do it soon, while I have leftover biccies from the rolling road day ;)
  2. neil kaye Forum Junkie
    england
    scary picture ...i prefer the old RJ with the dress on ;)
    glad to see the car looking good again mate :thumbup:
  3. 1990
    1990 Paid Member Paid Member
    Rochdale, Lancs
    I'm dissapointed you didn't pose with a bikini on and a soapy sponge.
    yeah like that will ever happen! I never wash my car.
  5. milesmk2 Forum Member
    Thats because your always too busy helping everyone. Have a day off from it for once ;)
  6. shaz8389
    shaz8389 Forum Junkie
    He does all his forum stuff while he's at work though. He gets paid to help us.
  7. milesmk2 Forum Member
    I take back what i said.
  8. rubjonny
    so I decided to put some new eibach springs on to replace the sagged boges, and this happened:
    [:x]
    Tried welding a nut onto it 3 times but no luck,. In the end a mate of mine came over with his van, which comes complete with fitted oxy torch. inner nut burnt off and a large set of levers got the shock out complete with what was left of the bolt still in it
    Success!
  9. rubjonny
    some of you may remember me asking you to measure your shaft so I could compare to mine, well this is the result:
    and finally to bring you up to date, car is currently like this while I track down a pesky leak. On the plus side it finally gives me the opportunity to redo all the car wiring to my own specifications :thumbup:
  10. tech1889 Dan Forum Member
    Essex UK
    Looks good mate good to see your still spending little time on it :)
  11. rubjonny
    emphasis on 'little' :lol:
  12. Trev16v
    Oxfordshireland
    What particular aims do you have regarding the new wiring looms?
  13. rubjonny
    a few optimisations mainly, for example the mk2 dash loom has a load of spade connectors in the middle which will all be deleted (between heater live, and glovebox light for example) the wires for the heated washer jets will be dragged out and run via engine bay as per mk3 golf. using mk3 ciggy lighter and stereo wiring mainly as mine has been cut, plus it'll have the power feeds for my vag-com port in it as well. looking at using mk4 twisted pair speaker cabling, though i may not bother. any thoughts on why mk4 speaker wires are twisted, any advantages of using this over normal mk2/3 wires?
    I'm also looking at attaching the wiring to the bulkhead as per mk1 rather than havign it clipped to the dash, as it'll make remioval/refitting of dash much easier. plus the clips have pulled off the dash behind the glovebox!
    the lighting loom will be a combo of mk2 and mk3, taking the mk3 round connector for ease of slam panel removal, with mk4 relay box added in containing my relays for the headlights. i plan to put a mk4 battery box onto it as well, thereby ensuring all live feeds are fused. plus i will use the 3 pin plug on the back for my fan and light relays to reduce the load and cable runs from fusebox.
    for the rear loom i have removed the mk2 pump wiring and added in mk3 pump wiring, plus added in a mk4 rear 12v socket :thumbup:
    edit: plus a small 'secret' project that I'm still hashing out, all will be revealed later :lol:
  14. rubjonny
    Oh and I'm going to redo my corrado 1 touch loom and move the control box. atm the lengths are waaaaaaay too long so it'll be cut right down, should save a fair bit of weight in excess copper :lol:
  15. shaz8389
    You're doing it to satisfy your strange wiring fetish...
  16. rubjonny
    well i thought that much was obvious ;)
  17. Dan W
    Dan W CGTI Regional Host
    Penryn, Cornwall
    I'm not sure why the speaker wires are twisted in a mk4 loom. Twisted speaker cable is a no no in the hifi world, better quality sound from a flat cable running side by side
  18. rubjonny
    alrighty skip that idea then
  19. lufbramatt Forum Member
    Rochester, Kent
    Twisted pairs have better rejection of interference, probably a good thing in an electrically noisy car environment. that's why network cables use twisted pair.
  20. Trev16v
    Oxfordshireland
    Plus the driving circuits must themselves be balanced in order to benefit from a balanced transmission line. Which perhaps car amplifier outputs are. But it really isn't going to matter a t*ss. Use whatever looks cool.
