Seat sub frames?.
Discussion in 'Track Prep & Tech' started by KeithMac, Aug 18, 2023.
  1. KeithMac Forum Junkie
    Kazakhstan
    Hello all, into the interior now with my MK2 Restoration.
    I've been stripping my seat subframes and they look bent?.
    Believe these were Corbeau frames but could be wrong?.
    Before I straighten them up can anyone think of a reason why they may be that shape?, I'm sure my seat runners are flat.
    Was going to straighten them out and possibly reinforce them before painting.
    20230818_073317.jpg 20230817_183031.jpg 20230817_192206.jpg 20230816_195553.jpg
  2. PhilRyder
    They look like something I’ve made in my shed! Can’t help with the straightness issue though. Although I’m going to say they should probably be straight.
    daNpy likes this.
  3. PhilRyder
    Frames I made for my BMW. Mr Corbeau should be ashamed of himself. Sorry still can’t help with the issue [:$] IMG_0531.jpeg
  4. daNpy Forum Member
    NL
    To be honest they don't look too sturdy to me. A L-profile on the sides would help a lot.
  5. KeithMac Forum Junkie
    Kazakhstan
    I had 20mm spacers all round, might straighten them all out and welded some 25mm box section to the top..
    As said I was a bit disappointed when taking the paint off to see the welding etc, they weren't cheap either iirc..
  6. daNpy Forum Member
    NL
    Why don't you just make em like this:
    It's supposed to be a track car, right? I have something similar.
    theboysmiffy likes this.
  7. PhilRyder
    Seat bases are silly money for what they are, especially when they are probably made in China.
    KeithMac likes this.
  8. daNpy Forum Member
    NL
    I don't disagree with that but they are part of your safety.
    Sandtler used to heave neat steel plates with slotted holes which could be welded to the bottom of your car for lowest seating , but I can't find them anymore on their site.
    I also used tubes of 30x30x3 mm which are welded in the car on reinforcement plates with the specified cm2 from the FIA manual.
  9. KeithMac Forum Junkie
    Kazakhstan
    Yes, box section is the way forward, I'm not really worried about what it weighs.
    daNpy likes this.
  10. theboysmiffy
    theboysmiffy Paid Member Paid Member
    Gateshead
    Do these slide into the existing channels?
  11. KeithMac Forum Junkie
    Kazakhstan
    You wouldn't get the seat far enough forward with those, I'm only 5'10..
  12. daNpy Forum Member
    NL
    Slide? They're supposed to be welded on the sill and tunnel. Preferably with bigger plates.
    On these you can mount sliding frames. I've got that for the driver side.
  13. daNpy Forum Member
    NL
    Yeah you have to remove the ridiculous original front seat attachment there.
  14. KeithMac Forum Junkie
    Kazakhstan
    I've chopped enough out already, sick of welding by now lol .
    If I modify my subframes at least it can go back to standard seats at some point (unlikely though).
  15. daNpy Forum Member
    NL
    I can understand, but when I first saw the original seat mounting, I thought nothing but "that's unsafe"
  16. KeithMac Forum Junkie
    Kazakhstan
    The VW 3 mounts or my subframes?.
    I could remove them and welded in some box section down both sides I suppose.
    I've listed the seats and frames for insurance so I don't know what they would make of chopping the OEM mounts out?.
    I've got a mate who's going to cut me some heavy duty 30mm box section for now to repair the Corbeau frames.
    I've been stripping all the Bitumen off the floors tonight back to bare metal so I suppose now's the time to weld runners in..
  17. daNpy Forum Member
    NL
    The VW 3 point mounting of course ;)
  18. KeithMac Forum Junkie
    Kazakhstan
    Managed to strip the bitumen out (what a job that was!) and Epoxy Prime my floor.
    Think I'll modify the frames to fit in 4 corners to the floor but keep the OEM floor brace / front seat mount.
    Never gave it much thought 20 years back when I fitted them but it is a bit of a p1ss poor design!.
  19. daNpy Forum Member
    NL
    Yeah the bitumen is some work to remove.
    The parts on the floor you can bust out with a prybar when cold. On the tunnel you need to heat it and then remove it with a putty knife.
  20. KeithMac Forum Junkie
    Kazakhstan
    I did hot air gun and scraper for the floor, then wire wheel, then thinners and rags.
    Had a good look round the transmission tunnel and decided to leave that on.
    Main reason for doing the floor was it had all cracked and water had been sitting underneath parts of it.
    At least if I have a leak now it won't get under the Epoxy.
    daNpy likes this.
