Seatbelt Anchor replacement
Discussion in 'Mk5' started by paulm2322, Feb 18, 2023.
  1. paulm2322
    paulm2322 Paid Member Paid Member
    Liverpool, UK
    Hi,
    I need to replace my wife’s seatbelt anchor (drivers side). I know I have to remove drivers seat to do job. Is it correct that once I disconnect the battery I will need to reset air bag light via vcd etc?
    thanks,
    Paul
  2. daNpy Forum Member
    NL
    If you disconnect the battery, it should not give an airbag light as far as I know.
    paulm2322 likes this.
  3. GVK
    Disconnect the battery and allow 15 mins before you touch anything airbag related.
    Sometimeson mk5s tho it does put the light on though, do you have means to reset the air bag?
  4. paulm2322
    Liverpool, UK
    Cheers folks. I don’t have device to reset airbag if I get warning light. Have to go the garage if it comes on.
