So here goes I'm going to build a budget scirocco 16vt
Discussion in 'Scirocco' started by DR_G60_91, Nov 3, 2015.
Tags:
  1. DR_G60_91 CGTI Regional Host - Kent
    Meopham
    So fare I have a very clean mk2 scirocco 1.8 carb
    The parts I have acquired so far for the engine conversion .
    Kr engines x2
    Audi s2 pistons and rods
    T4 turbo
    Badly modified 16v intake
    S2 stainless manifold with 5th port removed
    Ross machine racing fuel rail and injectors + regulator
    G60 wiring harness converted to fit scirocco
    + ecu I collected for my g60 golf .
    Will get some pics up of the parts and what I've got to do to fit and make it all work . Watch this space ......
  2. DR_G60_91 CGTI Regional Host - Kent
    Meopham
  3. DR_G60_91 CGTI Regional Host - Kent
    Meopham
  4. DR_G60_91 CGTI Regional Host - Kent
    Meopham
    If any one wants to put any input or ideas into this that might help , that would be much appreciated
  5. DR_G60_91 CGTI Regional Host - Kent
    Meopham
    Ctn gearbox on the way and I'm just starting on the s2 pistons
  6. Toyotec
    CTN= very tall final drive though.
  7. DR_G60_91 CGTI Regional Host - Kent
    Meopham
    I wanted the box as you can hit 60 in 2nd and want a low revs at motorway speeds .
    I've started filing the Pistons to miss the oil squirters today will get some pis up when I can . Lots off engine parts being delivered tomorrow. Engine rebuild kit ??
    Any one have a short runner manifold to take a g60 throttle body and my fuel rail ? Or got any better ideas ? Cheers
  8. afbiker02
    Bury St. Edmunds
    This sounds interesting, might be easier to find in the members gallery though. Looking forward to more pictures of your progress
  9. Nige
    Nige Paid Member Paid Member
    Sounds interesting :thumbup:, but a 3.1 FD box ? That`ll just blunt everything [:s]
    It`d be quicker to 60 with a 3.6 Box surely [:s]
    Have you not thought about the `usual` KR lower and 1.8T upper hybrid inlet manifold ?
  10. DR_G60_91 CGTI Regional Host - Kent
    Meopham
    I think I've found a s2 manifold with throttle body just waiting for the bloke to get back to me .
    The gearbox I've looked into quite a lot . And for the fact I got the ctn gearbox for 150 . I know a few people running these and they seem up to the job . It was between asd or ctn and I have a ahu aswell
    Finally got my engine rebuild kit Friday aswell so I can start building the engine .
    Also rebuilt my s2 callipers just nee a 9 inch servo and I found a transporter brake master cylinder to match the callipers
  11. Toyotec
    Your call.
    3.68 FDR can also hit 60 mph if you design your engine with revs and torque up to 7300 rpm. You will have much more axle torque for acceleration.
    All the 3.125 applications I have driven, including some 400bhp ones feel crap IMO.
    Nige likes this.
  12. DR_G60_91 CGTI Regional Host - Kent
    Meopham
    Hi eddy cheers for the input how about a cha gearbox or could I possible make a gearbox out of the 2 I know the final drives are quite different
  13. Toyotec
    I would say the CHA is a bit too short on a turbo engine, especially as this is a Scirocco.
    For example an engine with a mild 200 lbft, a first of 3.78 and a FDR of 3.94, will make for a very useless pull away if you are hasty on the throttle.
    You might find the ABF CDA/DPA gearbox to be more suitable.
  14. sparrow Paid Member Paid Member
    Leamington Spa
    If you use a short intake manifold, you can use the fuel rail from a 1.8t. Just knock up a couple of brackets to support it.
  15. big_wig_074 New Member
    what are you doing for management?
  16. Toyotec
    Ryan was going to run a G60 ECU I believe.
