Someone with 1.8 16v weber and megajolt? ?
Discussion in 'Carburettor' started by ivanrs, Oct 2, 2015.
  1. ivanrs New Member
    Someone has a mapping to megajolt work?
    Engine
    1.8 16v head ported
    Weber 45 dcoe
    Rom 98
    Thank
  2. ivanrs New Member
    thank you very much, have if someone has an image mapping megajolt
  3. jamez Forum Member
    Netherlands
    Heres my map from 2008 with 40's on a modded passat 9a, i have now an abf with 45's but dont have the map to hand. If you need it i can get it from the ignition from the car..this map is a bit upside down but i had just installed it and was learning to write maps..
    http://www.autosportlabs.org/viewtopic.php?t=2085
  4. ivanrs New Member
    Hi, I saw your map on, the problem is that I do not open the file. if you can send me a picture of your current settings (2.0 16v) ??would be very grateful
    My adress email is: ivanrodriguezrodriguez@hotmail.com
    to start with a map on a similar engine configuration
  5. ivanrs New Member
    another matter : the original (oem)coolant temperature sensor for ecu, to be located head .You could use it ???
    the wiring conexion would be: 1 pin to aux. imput and 2 pin ground.is correct
  6. Toyotec
    You would need to know the sensor characteristics of resistance to measured temperature.
    Then once this is all good and your fuel control is reasonable, you can start to refine the ignition map.
  7. jamez Forum Member
    Netherlands
    You need to install the megajolt pc software v4.0.2 http://www.autosportlabs.net/MJLJ_V4_Downloads and download the mjlj file from the link i posted the open the file with megajolt.
    As for the temperature sensor you can use the oem one and calibrate it it the software but its only to give advance automatically during cold starts or to reduce the ignition if running really hot, i never bothered with it.
    ces likes this.
  8. ivanrs New Member
