Stud and nut conversion
Discussion in 'Track Prep & Tech' started by S3ALEX90, Sep 28, 2016.
  1. S3ALEX90 Forum Member
    Does anybody know where I can get a stud and nut conversion from for a mk1 golf.
    Thanks
    Alex
  2. Sirguydo
    Bolton
  3. mickey marrows Forum Member
    Garage Midnight do very high quality motorsport ones, highly recommended :thumbup:
  4. Savagesam
    Why is that so cheap per stud but the sets are 80+
    I'm going to buy some because I like them, they look cool and the balancing act isn't much fun.
    Someone tell me what size thread I need?
    Also could you not just use a threaded bar the same length?
  5. Toyotec
  6. Chewie Forum Member
    Nottingham
    M12 x 1.5
    later Golf's M14 x 1.5
    You could use threaded bar, you could also replace your aux belt with a pair of stockings, never replace the cam belt and use second hand engine oil. Just because you can, doesn't mean it's a good idea. The purpose made studs are tempered so they don't stretch or shear.
  7. Savagesam
  8. The Green New Member
    Select the set, and then check again if in stock or not. When just landing on the page it will indeed say not in stock.
    Unless I bought the last set last week.
    Now I must say I tried to fit 1 bolt and 1 nut when being in the morning traffic jam, straight out of the package and the nut stops after 2 rotations.. found a small mark on the bolt.. Will be running it through the cutter, unless they all have it, then its back to sender..
  9. vw-aj New Member
    Thank you for the link Toyotec.
  10. Savagesam
    Thread revival [:D]
    I bought a kit from elite developments, took so long to turn up, i forgot I ordered it. Having a look at them, they are really long. I accidentally ordered 90mm when checking the order. I dont run spacers or anything, so are they going to stick out too much? I don't want to take them out of the packaging because then I can't return them.
    What lengths do others run?
  11. mat-mk3
    mat-mk3 Administrator Admin
    Bristol
    The elite ones look the same as the ones from garage midnight who suggest 90mm being for large spacers so would expect them to be a bit long. It's a shame they are the wrong thread or I would have bought them from you!
  12. Savagesam
    Guess they're going back then! :(
    They're awfully heavy for 20 studs and nuts too.
  13. Toyotec
    Seems like Elite's site is down, but you can find similar online.
