Tacho feed from coil- mk3 abf
Discussion in 'Electrical' started by jigarai, Mar 16, 2024.
  1. jigarai
    jigarai Paid Member Paid Member
    Hi Folks,
    Newbie here- am the final stages of getting an ABf install in a t25…
    am trying to workout how to hook the green wire for the tacho signal on the ABF loom onto the ignition coil.
    my understanding is a need to solder on a connection on one or other side under the little flap on the bottom of the coil… is this correct? If so how do I identify which side?
    Or am I completely off track?
  2. PhilRyder
    We did this for MK3 AGG into MK2. This is where we needed to solder the wire.
    jigarai likes this.
  3. daNpy Forum Member
    NL
    Does the abf computer have an output for the tacho?
    I make amplifiers so the original tacho works with the signal :)
  4. jigarai
    Thanks Phil! Perfect
    PhilRyder likes this.
  5. jigarai
    Thanks man! The original setup was on a digijet computer so it should just swap over. If it’s not right I’ll be sure to say hi.
    daNpy likes this.
