Tell us what you would like!...
Discussion in 'JTech Performance Parts' started by JTechPerformance, Apr 16, 2015.
  1. JTechPerformance Club GTI Sponsor and Supporter Trader
    Let us know in this section what products you want to be able to buy from us. It maybe things that have been difficult to find, or that you can't find elsewhere. With contacts across the industry there shouldn't be much that we can't help with.
    Fire away! :thumbup:
  2. JTechPerformance Club GTI Sponsor and Supporter Trader
    Don't be shy folks! Any suggestions for group buys considered too!...
  3. mk2redvr6 Forum Member
    Roll cage for a mk2 how much fitted
    Cheers
    JTechPerformance likes this.
  4. JTechPerformance Club GTI Sponsor and Supporter Trader
    Hi mk2redvr6,
    Plenty of variables to consider: Type of cage, painted/powdercoated, bolted in or welded in, sunroof, tube material, interior already out?, sound deadening removed? etc etc. - Using those examples as a basis, would you be able to specify in a little more detail what you were after? Then we can go through some options with you!
    Thanks!
  5. afbiker02
    Bury St. Edmunds
    What can you tell me about mk4 engine mounts into a mk2 1.8t conversion?
  6. Craigcorson
    Craigcorson Forum Member
    Inverkip
    Stuff I've struggled to get for the mk2 is as follows
    modified water outlet for 16V engine with carbs
    radiator for carb clearance, i would like a kit that gives you room in front of the carbs and fresh air
    quick rack ( ended up doing the quaife quick rack group buy)
    no power steering quick racks for mk2
    chassis stiffening kit similar to the harry hockley one you get for the nova/corsa
  7. JTechPerformance Club GTI Sponsor and Supporter Trader
    Hi, pretty much a case of welding mounts to the chassis legs and to the subframe for the dog bone mounts :-)
    I can sort some more pictures if you'd like?
    afbiker02 likes this.
  8. JTechPerformance Club GTI Sponsor and Supporter Trader
    Hi Craig, we'll take a look at the above! I'll keep you posted!.. Custom stuff like the radiator might be easier to undertake at our workshop, as most applications of this nature are all quite different!
  9. afbiker02
    Bury St. Edmunds
    Pictures would help a lot and measurements if you have them too please
