The Dubbers "Ideal" tool box
Discussion in 'Tools, Equipment & Fasteners' started by turbotommy, Oct 12, 2010.
  1. turbotommy Forum Member
    Newcastle upon tyne
    Been meaning to start this thread for about 2 years [:$] i'm exhausted but its bugging me ,so no time like the present :lol:
    I want to set a list of tools needed to dismantle a complete golf (be it mk1/2/3) no more,no less.
    Its not the "ultimate tool box" or a "money no object" wish list,but the DIY novice list of the minimum needed or will help :thumbup:
    The reason is,part of my project costs went WAY over budget through tool purchaces,and not having the right tools both cost me time & money [:x]
    I'll start this off as an incomplete list then come back to it to revise if i think of more things too add or if others want to add their 2p worth (please feel free [:D])
    Maybe a brief job description for odd tools would be an idea?
    I had 2 tool cases with just about enough to break a car so here goes!
    (in the next post to keep it neat)
  2. turbotommy Forum Member
    Newcastle upon tyne
    A good trolly jack + (block of wood comes in handy)
    NEVER EVER EVER get under a car if its held up with the standard scissor jack!!!
    Axle stands
    Sockets;
    Quarter drive sockets
    8mm - 13mm
    8mm (inner arch bolts)
    9mm (02A flywheel bolts)
    10mm very common
    12mm
    13mm very common
    13mm LONG (pedalbox /servo,to name 1 job) MUST HAVE!
    14mm
    15mm
    16mm or 5/8" is the same
    16mm (some front crossmember bolts)
    17mm very common
    18mm very common
    19mm very common
    21mm (old top nuts mk2)
    22mm (new front suspension top mount nut with impact driver...)
    23mm
    24mm (steering wheel nut)
    30mm (hub nuts)
    Spanners
    8mm
    10mm very common
    11mm (brake hose spanner) very important if doing brakes!
    12mm
    13mm very common
    14mm (thin required for brake pipe)
    15mm common enough
    16mm (deffo needed for some jobs)
    17mm very common
    18mm common (both socket & spanner for front suspension bolts mk2 golf)
    19mm very common
    21mm (
    22mm (suspension top nut / lambda sensor)
    24mm
    Ratchet spanners are brilliant (10mm & 13mm most used)
    Allen head sockets (sizes to follow)
    M8 spline (driveshafts)
    M10 spline (mk2 starter motor)
    Mole grips
    Pliers / needle point etc...
    copperslip & WD40/plusgas
    good 1/2" breaker bar,3/8 smaller one a good idea (a long length of pipe will do if you don't get a breaker bar)
    Ball joint splitter
    Nut splitter ( if your track rod end just spins to name 1 use)
    Topmount tool (front suspension)
    Impact driver (disc retaining screws)
    Lump hammer = brute force & ignorance (for when temper gets the better of you)
    Cambelt tensioner tool
    Irwin bolt grippers (life saver for rounded rusted bolts) at 2 x 20.00 for both sets not cheap mind.
    Caliper wind back tool (if doing 2 x rear calipers more than twice)
    Stilsons (stubborn bolts)
    Blowtorch
    Telescopic magnet "thing" (for retrieving the nuts and bolts you WILL drop)
    just for starters so i'll finish it with good time (again & again)
    Hope it helps those who are new to cars or tools wondering what to buy for jobs etc..
    Thoughts welcome [:D]
    cupracraig likes this.
    Tommy, take and add to post 1 as you wish :thumbup:
  4. turbotommy Forum Member
    Newcastle upon tyne
    Cheer's Chris!
    added you imput :-)
    Feel free to edit the post if you wish/can etc..
    I've been meaning to "edit" my own tool box to remove those few tools that are never used too, they must of travelled thousands of miles (no joke) and STILL havn't been of use!!!
    Its a waste & weight,so must be put to one side (but not thrown out) as i'm sure many would agree?
  5. 2dubnick Forum Junkie
    Worcester
    I got a 48 piece spanner set from screwfix for 22quid thinking it would be pretty rubbish but handy, its lasted me over 3years of hard use including putting scaffold poles on some of the smaller spanners and iv never broken one, best 22quid I ever spent on tools. They dont list the same make one anymore on the website thou.
    A small selection of 6sided sockets is always handy for any bolts you may be worried about rounding off.
  6. MUSHY 16V
    aberdeen
    rear caliper wind back tool
  7. turbotommy Forum Member
    Newcastle upon tyne
    Totally agree,it does not always need loads of money to get a competent "tool box" also i should of said that for most BIG nuts a 6 sided socket is the way to go,although some jobs need a 12 sided (like the 9mm 02A clutch flywheel bolts) and only a 12 sided will do.
    Irwin bolt grippers are a life saver on our now old cars,as can bolt splitters but i'll get to them (i think this thread needs some more of my time,its getting complicated lol)
    Tommy.
  8. turbotommy Forum Member
    Newcastle upon tyne
    Thread tidy.
  9. A.N. Other Banned after significant club disruption Dec 5th 2
    Quarter drive sockets are also v. handy, 8 - 13mm
  10. Gaz37 The Grouch. Paid Member
    ZZ plural 9 alpha
    1/2 inch drive UJ & a couple of extensions for undoing manifold/downpipe joint on later cars.
  11. rubjonny
    good set of allen socket bits, quite a few allen bolts to be found. dremel for grinding of stuck nuts/bolts.
    18mm isnt a common size on the MK2 at all, the only bolt I can think of thats 18mm is the carrier bolts for 256/280mm calipers. note also new top nuts for mk2 are bigger than the stock size.
    old top nuts are 21mm, new top nuts are 22mm. also, lambda probes are not 24mm, they're 22mm. Not that it matters on a MK2 as they very rarely have a lambda ;)
  12. Ben S
    Ben S Forum Junkie
    Essex
    Gaz I do the manifold to downpipe with a ratchet spanner
    Hose pliers are useful for where hose clips haven't been replaced with jubilee etc
  13. Funky Diver Forum Member
    Darlington, UK
    Impact Driver - with a 1/2" drive.
    I've used it for SOOOoooooo many odd jobs that it's silly not to have it, more for dismantling than anything else.
    The other essential tool... 2lb mash hammer / lump hammer
    I only added the images for folks that have never used them before (ie complete novice :))
    Pin punch for door pins, and other stuff.
  14. Matt82
    Matt82 Forum Addict
    GTI Scene
  15. lufbramatt Forum Member
    Rochester, Kent
    long handled 7mm allen key for mk3> front brake caliper slider pins and rear caliper carriers.
  16. Tall Paul Forum Member
    Cambridge
    Set of Stilsons - pretty much anything that doesn't want to come undone
    Set of wobble bars - head to manifold bolts, and other not easily accessible bolts
  17. StuMc
    50? 20` 47 N - 06? 57` 57 E
    From your inital list;
    `16mm or 1/2" is the same`
    13mm is closest to 1/2"... :thumbup:
    Also essential, is one of these;
    Has Allen, Torx, and spline bits (two of each in different lengths) with 3/8" and 1/2" drive adaptors.
    Perfect for things like inlet manifolds, driveshafts, and various bracketry. Even has the correct spline bit for head-bolts.
    Costs about 15-20 from those tool sellers you see at most shows. :thumbup:
  18. pRot3us Forum Junkie
    Wales
    :lol:
    Does anyone actually have a set of these that aren't rusted to f**k?
    I swear they start rusting the moment you first open the box.
    I'll add Irwin bolt grippers :thumbup:
    and a good set of cold chisels (bye bye seized top mount nuts from hell [​IMG] )
  19. StuMc
    :lol:
    It doesn`t help that it`s been open to the rain on more than one occasion, and it also `discovered` the leak in the Mk3`s boot.
    Ah...top mount nuts...you need one of these! ;)
  20. turbotommy Forum Member
    Newcastle upon tyne
    All replies read peeps (many thanks) and post above now edited a bit more.
    Whilst the spline & torx sets are great (and reccomended),i think if we keep it to sizes for specific jobs so the people who will only use it once can just buy 1 instead of the 20.00 box set,as those of us who tinker ALL the time,probably have a set or know purchase of one is on the cards very soon ;) :lol:
