Throttle pedal conversion not working! HELP!
Discussion in 'Engines' started by Garyn Williams, Oct 1, 2023.
  1. Garyn Williams New Member
    Hi guys, I'm trying to get a DBW throttle pedal to work in my conversion but cannot get the wiring right.
    It has a seat Ibiza cupra loom with the older round type connector which is for a actuator type throttle.
    I am trying to fit a later MK4 golf throttle which I know has been done.
    Wiring seems fine but I either get full open throttle or full closed.
    Any ideas or diagrams would be very much appreciated.
    Thanks in advance
  2. Savagesam
    Isn’t there a big ecu/loom change between narrow and wide band?
    I’m sure someone will confirm
  3. rubjonny
    the pinout is ever so slightly different, this is what you need for late pedal. ECU pin, blue plug, pedal:
    34 -> 1 -> 6 - Pedal Sensor 2
    72 -> 2 -> 1 - 5V
    73 -> 3 -> 2 - 5V
    36 -> 4 -> 3 - earth
    35 -> 5 -> 4 - Pedal Sensor 1
    33 -> 6 -> 5 - earth
    oh and post up the part number of your pedal, diesel ones wont work on petrol engine
  5. Garyn Williams New Member
    @rubjonny, Thanks for the diagram This is what i had whilst doing my research so glad i was on the right track haha.
    I am on my 3rd now as iv just ordered a Actuator type as i cannot get these to work.
    1J2721503C
    8N2721503C
    I have just ordered potentiometer 0205001045 as this is what the plug on the loom is for.
    Any other suggestions as i would like to just have the pedal rather than an adapted unit.
