What front brakes on a 89 Corrado ?
Discussion in 'Corrado' started by watercooled, May 20, 2021.
  1. watercooled Forum Member
    Nelson,New Zealand
    Thinking late Golf mk2 GTI or Mk3 caliper setup,can someone tell me,have a set of front disks that are ok so may change the pads,cheers.
    Surely it depends on what model? 8v, 16v, vr6?
  3. watercooled Forum Member
    Nelson,New Zealand
    Oh sorry,should have 1.8 KR,thanks
  4. Tristan
    I'd be shocked if they are anything other than mk2 16v 256mm discs and pads.
  5. GVK
    Yeah as Tristan says a KR car will have the mk2 16v front brakes already.
  6. watercooled Forum Member
    Nelson,New Zealand
    Thanks guys,new Mintex ones I have don't fit as they are mk2 8v,most likely sell them as the 87 gti I had is long sold.
  7. Tristan
    The other factor... Because the brake upgrade is so common on cars not running g60 / 280mm discs, you'd always want to check it hasn't been upgraded in the past.
    Mk2 8v should be 239mm.
  8. dodgy
    Measure them, even between the two golfs here there are differences, ones vented and one solid, that was before upgrade.
