Which modern shifter is a direct fit onto a Mk2 VR6?
Discussion in 'VR5, VR6 & Wx' started by 1990, Feb 5, 2013.
  1. rubjonny
    thats not the 6K 99-02 ibiza one, they run the same unit as polo one I show above.
    You have one from the 02 onwards 6L chassis, will still work just need more mods to the shell same as MK4 one would
  2. Blauswartz 16v New Member
    It came from a 2002 ibiza.
    Will need some modifications to fit so next on list is the tower and do I need TT stick?
    Thanks
  3. rubjonny
    TT stick isnt strictly necessary, I used one as its already threaded to take the MK2 gear knob plus in my case it moves the stick a bit closer to where I like it. YMMV
  4. Blauswartz 16v New Member
    I'll want to use mk2 gear knob.
    Do any others come threaded for plug and play?
  5. rubjonny
    no, but you can either tap it or chop and weld the end of an earlier stick on. the tt sticks can be picked up cheap, but then since you have a 6k ibiza stick you could just use the whole tt assembly rather than mess about swapping the stick over :lol:
