Would an engine from an Audi A3 2.0 in mrk golf conversion
Discussion in 'Mk5' started by Cameron parsons, Aug 11, 2022.
  1. Cameron parsons New Member
    Hi I was wondering if anyone could help me I’ve got a mrk 5 golf 1.4 petrol I want to put in a 2L Audi A3 engine would they have the same engine mounts or would the Audi engine fit right in Wanna do a conversion.
    Thanks
  2. Adamss24 Forum Member
    Everything will fit if you’re determined to make it work ! Engine mounts and driveshafts will be your main concern as you might need to swap the donor gearbox as well !
    I have 2x mk2 fitted with Diesel engines and one with a mk3 petrol engine, all needed minor fabrication skills but the electrics took a bit of a faff to get right !
  3. AllanWorms New Member
    the 8P A3 and MK5 Golf are basically the same car - the mounts etc are all the same.
    My Touran is basically a MK5 Golf, and I fitted a 3.2 VR6 from an A3 3.2 with Golf R32 ECU etc.
    You won't be able to use the Audi ECU, without some serious "tuning" work. You can get a VW ECU though, as the loom will be the same if you match the engine codes.
  4. Tristan
    Is it worth doing when you can buy a 2.0 Golf relatively cheap?
