Xenons...’Blowing fuses’
Discussion in 'Electrical' started by MarkGolf, Jul 2, 2004.
  1. MarkGolf Forum Member
    Zimbabwe
    I've managed to put Audi S3 xenon's into my R32 look headlights on my golf...
    All well and good, but I turn them on, they'll stay on for about 10 secs, then the fuses for them blow...
    Can i put a larger ampage fuse in to solve the prob?
    Crrently using a 10 amp fuse
    Possibly need to do the MK1/2 uprated loom mod? You use a direct live feed to the headlights running off switched relays, theres a guide on Matey-Matey.
    But does the MK3 already have the loom setup this way?
  3. MarkGolf Forum Member
    Zimbabwe
    Not sure on the loom situation, but all sorted now, was just a case of a 20 amp use!
    good good! Keep an eye on your wiring in case it starts to melt tho ;)
  5. Rallye Forum Junkie
    lol yeah, nice engine fire to finish the project off
    I prefer black paint to silver anyway :lol:
  7. AndyG
    AndyG Forum Member
    Worcestershire
    xenon's need a minimum of a 15A fuse because of the high start-up current required
  8. zak. Forum Member
    To get the xenons going takes a lot of current but once they are running they use less current than conventional lights.
  9. The Other Simon Forum Member
    I give your headlight switch a week, before it blows.
    The Mk3 headlight electrics are quite fragile, with both the headlight switch and the column stalk only just having thick enough wiring for stock headlights. Uprating the fuse is a stupid idiotic idea - it is there to protect the expensive parts of your electrics. If it is blowing then you have a problem.
    I assume that you have fitted the high pressure washers and the suspension sensors for the automatic self levelling? Otherwise your car is illegal.
    If you are serious about keeping the lights, you need to look at fitting relays to cope with the higher current drain.
    Simon.
  10. Matt Golf Forum Member
    Kent
    Probably not.......
  11. Rippsy Forum Member
    Surely since its just a current spike thats knocking the fuse out he could just fit a capacator on the line so it drains that instead of pulling on the fuse? or am I being stupid?
  12. AndyG
    AndyG Forum Member
    Worcestershire
    being stupid :lol: :lol: :lol:
  13. MarkGolf Forum Member
    Zimbabwe
    Got them going off of 15A fuses now.
    Half my car is illegal anyways, so not worried about ugly washer jets and self leveling lark.
    I've consulted 3 people I know with xenons on their mk3 and they've had no probs what so ever and their running 25 and 30 amp fuses..
  14. MarkGolf Forum Member
    Zimbabwe
    Did forget to mention Im using a wiring harness from an E46 bmw for the headlights..
    From fuse box - relay - headlight..
  15. The Other Simon Forum Member
    That does make somewhat of a difference.
    So if you are not feeding the headlights through the switches, how are you blowing fuses? Surely you should be blowing the inline fuse from battery to the relay?
    Simon.
  16. MarkGolf Forum Member
    Zimbabwe
    That was when I used the OE loom.. I got the E46 a few days after and just replaced the OE wiring with the BMW..
    Just slightly thicker with a relay..
