020 Clutch Pushrod..
Discussion in 'Transmission' started by KeithMac, Dec 30, 2022.
  1. KeithMac Forum Junkie
    Kazakhstan
    Been probably 20 years since I last fitted an 020 so bear with me!.
    I've searched high and low for correct pushrod direction.
    I have landed in "pointy" end towards the clutch release plate and fitted it that way, is this correct?.
    To make it simple I'd say there's a pointy and a blunt end, rather than explaining it any other way.
    The only thing that makes me 2nd guess is the "pointy" end is a very good fit into the release bearing.
    Cheers all.
  2. Zender Z20
    Mine is blunt end at release bearing and pointed end at clutch plate.
    Did buy a 'new' one from VWHeritage and it turned out to be Topran.
    Also turned out to be off true and went back to the original 75K one which although it looked worn was still the correct length.
    There's pics somewhere in the later pages of my 'Isaac' thread if you want to compare.
    KeithMac likes this.
  3. KeithMac Forum Junkie
    Kazakhstan
    Thanks @Zender Z20, I have an original OEM pushrod but it looked worn on the end, will have to measure it.
    Topran is the one I've just fitted, it "looked" straight but I may have to double check that!.
  4. Zender Z20
    Topran rolled in stages across a known flat surface, the original ran freely.
  5. Hotgolf
    Smelly Cornelly
    Round end on bearing
  6. KeithMac Forum Junkie
    Kazakhstan
    Thanks @Hotgolf , that's the way I fitted it in the end.
