020 gearbox splitting tool
Discussion in 'Transmission' started by mrglee, Jun 5, 2018.
  1. mrglee Forum Member
    I have a perfectly good box until I go backwards clack clack clack broken tooth on reveser idler.i have striped a few boxes in my time and fancy having a go at this one got a guy who can make the surport and splitter just need to know the measurements.
  2. Jon Olds Forum Junkie
    I usually strip an 020 without tools (except: cam idler stud/nut and bit of steel for O/P shafts), although I have done quite a few, so know where to
    hit with the nylon mallet.
    02A's not so easy...
    Jon
  3. KeithMac Forum Junkie
    Kazakhstan
    Have a look for Brokes 020 website, he has a trick using the little 5th gear on top of the input shaft and using the top casing to press the gearbox apart.
  4. Hotgolf
    Smelly Cornelly
    The upper input shaft/bearing can be tapped down with a plastic dead blow hammer whilst lifting the case up, no need for a splitter.
