Good afternoon all hoping someone could help me identify this noise https://youtube.com/shorts/3M3tvDVbtbk?feature=shares excuse the breathing this was a couple months ago when I done my ribs in also have another problem ragged the car the other day parked it up all fine next day clutch pedal was stiff and wouldn’t fully depress, wasn’t able to select gears, could select gears with engine off released the pressure from slave cylinder and clutch went to the floor, bleed it all but still stiff and won’t fully depress! Bleed it from master cylinder but still same removed the box and only thing I could see was the throw bearing (is it called that) wasn’t clipped to the clutch fork anyway hoping the whirring noise is a bearing or some sort and I’ll send the box to get rebuilt thanks in advance
Nope, was exactly the same noise with clutch depressed, done about 300miles with the noise, no worse no better, just an annoying noise at idle, a slight whine in-line with the rev range
Are sure it's transmission end? I would remove the serpentine belt and see if noise stops, could be water pump, Alternator or PAS pump if fitted.
Definitely transmission end, no pas, no air con already replaced water pump after that video, 99% sure it’s not alternator, car it was from didn’t make that noise, only thing I have no history of is the gearbox
