I need som help with vag com, i am using the full version of 409.1 to try and calibrate the throttle on a golf 3 1.6 AEE engine i have followed the procedure Procedure for performing a Throttle Body Alignment on Cable-Throttle Cars: These are cars with a physical cable between the accelerator and the throttle, but WITHOUT an ISV. Turn the key on but do not start the car. [Select] [01 - Engine] [Measuring Blocks - 08] Group 098 (Note: Some SIMOS or Marelli ECU's use Group 001 such as ADY & AEE engines) [Go!] [Switch to basic settings] Once you do this you will see the top right display say ADP RUN. The TB adaptation is being done as soon as you switch to basic settings. You will see the values change and hear the TB cycle for the first few seconds then it will stop. Leave it in Basic Settings for about 30 seconds. [Switch to Meas. Blocks] button and you're all set. Be sure not to touch the accelerator and make sure the engine is NOT running when you do this! However i dont see ADP Run come up at all when i follow the procedure, the throttle cycles, but as soon as the ignition is turned off and back on the code re appears any help will be greatly appreciated
